radiator repair?
Old Nov 14, 2006 | 11:27 AM
alongtheway1's Avatar
radiator repair?
i have a 95 4runner 3vze 4wd and i have a pin size hole in top of the radiator should i opt for a new radiator or is there some topical fix such as jb weld that would be up for the job. i would like to get this fixed soon so be honest all you truck techies out there. thanks scott
Old Nov 14, 2006 | 11:29 AM
Elton's Avatar
im sure you can use jb weld not to sure on how long it well last
Old Nov 14, 2006 | 11:33 AM
yeah i was thinkin that and i dont have the time to do a radiator swap right now so maybe ill try the jbweld
Old Nov 14, 2006 | 11:36 AM
da_bigg_wigg's Avatar
i had one. I soldered it a year ago. It hasn't leaked since.
Old Nov 14, 2006 | 12:12 PM
bruizer's Avatar
10 yrs....$200 ...replace it...........
dcg9381's Avatar
I JB welded mine as part of a "get home" repair.. It's a good indication that you'll need to replace soon.
Old Nov 14, 2006 | 12:13 PM
MMA_Alex's Avatar
deff replace it, but im sure jb weld would work for the time being if you need to put it off a few weeks. I just wouldn't use jb weld as a permanant fix.
Old Nov 14, 2006 | 01:25 PM
Toy-SkiTzo's Avatar
mine was patched with sumthing (not shur what exactly) when i bought it, but a year later the patch came off and i was left stranded. So dont leave the jb weld it there too long.
Old Nov 14, 2006 | 02:32 PM
Nic's Avatar
Nic
As already said, the JB weld will work, but it won't last. The top of the radiator on my 84 Camry started leaking and I patched it with JB weld. It would hold for a while and then it would start foaming from under the patch. I finally just bought another radiator.
It will do ya in the short term though.
Old Nov 14, 2006 | 03:36 PM
Guardian_Saint's Avatar
The Permatex #84109 with the black and white mixture will work fine, I have it patch on a civic rediator for more than 2 years, it still hold tight and haven't have a problem. That cost me only $5.00 I believe... If you need some just PM me.
indawire
Nov 29, 2015 05:05 AM
LotOMiles
Sep 14, 2015 11:45 PM
djpg2000
Sep 7, 2015 10:36 AM
