PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 [91] 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. Question-O2 sensor wire uhhooked but no CEL?
  2. Coils, Shocks, Torsion Bar
  3. 5th gear noise
  4. Idle up vacuum and other vacuum mysteries
  5. painted the stripes, grill, bumper, and rear fender rock guard
  6. seal question
  7. Power Steering ticking and ABS Deletion - advice needed
  8. 1993 3vze Air Filter Noise
  9. HowTo: Get that spare, out of there!
  10. 88 4runner v6 fan self destructs vausing extensive damage
  11. 22re pinging
  12. 95 4runner #6valve compression
  13. Idle Problems/ Bad AFM?? WEASY cams need adjustment??
  14. catalytic converter
  15. ignition issues plz help!
  16. 1995 toyota truck project HELP!
  17. Hardness using stock buckets.
  18. LCE pro vs street header?
  19. '88 4-Runner Hi Lift jack storage
  20. 1986 Toyota 4x4 SR5 Xtra Cab Restoration Questions
  21. Rebuild Questions
  22. 1st Gen 4Runner: Haunted by a relentless IFS Squawk
  23. HELP! IFS ADD front diff
  24. Question about the Timing change procedure?
  25. New member
  26. de-pining ?
  27. Thx a pantload Crower!
  28. 86 4runner bolts
  29. Got a 94 4runner need ac not working
  30. Power Stearing pump ticking.
  31. NGK BKR5EKB II in a 3.0 Is it possible?
  32. No start,no clicks on 86 truck??
  33. 22re possible fuel problems?
  34. no throttle response low rpm under load, bad tps?
  35. stuck front pulley bolt AAARRRRGGGHHH
  36. Just installed OME Kit
  37. Hard start
  38. Power Steering stopped working.
  39. 22RE Rebuild Tips/Tricks?
  40. '88 4runner A/C failure?
  41. Oil pressure gauge wiring harness
  42. 22re bogging
  43. Corner light problem
  44. What type of Head Gasket should I use?3vze
  45. Little gremlin i cant figure out
  46. nut size
  47. OverHeating Problem Solution For 3.0L
  48. NOOB questions about my 89 Pickup
  49. 4Runner 2nd Gen 4Runner headliner removal and rail instal info needed.
  50. Tail/marker/dash lights always on
  51. 22re Head Gasket Question
  52. need opinions
  53. 1st Gen 4Runner: Front shock bushing sleeve slid, preventing removal
  54. 93 pickup 3vze rear dif
  55. Fog light hookup
  56. 1993 yota pick up WON'T START
  57. New raditor question
  58. A/C high side fitting for gauges
  59. Factory Service Manual for 1987 4runner?
  60. Generic Fuel sending unit
  61. A/C Plugs?
  62. '93 Brakes
  63. Softopper-window tint question
  64. Throttle turns off and on like a switch
  65. Toyota factory maintenance oil change schedele 22re/3vze
  66. Starting problem
  67. front end howl
  68. Headgasket replacement
  69. Gear oil requirements for 87 4x4
  70. 94 4 runner 3vze lag and sputtery ecceleration
  71. Front Differential Gasket Question
  72. Pre welded sliders?
  73. Radator what is right
  74. Pickup to 4runner
  75. Which A/C compressors are exchangeable?
  76. 91 V6 Auto Sputtering at Idle & Drive
  77. 93 pickup 3.0 auto to manual swap
  78. Parts I can Eliminate?
  79. sick 22re
  80. Head Gaskets
  81. Replaced front main seal and O-ring but still leaks?
  82. Hesitant acceleration after warm start?
  83. advice on new shocks
  84. To advance or retard? 22re
  85. no power until 2500-3000
  86. Does 4runner A/C evap same with 92 pickup 22re
  87. tORSION Bars
  88. Busting Boots
  89. 22r jumps time please help!!!
  90. New Battery time - Which kind to get?
  91. Exhaust Replacement
  92. Help troubleshooting '91 22RE cruise control (vacuum switch?)
  93. Paintjob Question
  94. The infamous 22re ticking question
  95. Shift issue with auto
  96. Timing Chain confusion (pictures inside)
  97. Excess heat in the cab
  98. Repair Upgrade Door Panels
  99. '92 4Runner with 3.0 help
  100. 93 4Runner Trouble Starting after Heads Rebuilt
  101. un-needed vacuum lines
  102. 1988 4runner tie-rod ends
  103. Just swapped a W56 into my turbo/auto pickup.
  104. Drived great until warmed up.
  105. Pro Comp 33311: Which u-bolts to use?
  106. 22re cylinder scoring
  107. How I installed my AutoMeter water temp gauge
  108. Injector Rebuilding?
  109. Time to rebuild the motor
  110. Disabled ignition lock button
  111. Safe to say my ball joint is shot...
  112. Sway bar drop kit, or new sway bar end links?
  113. Diagnosis Vid: Will not go into gear!
  114. Just noticed in FSM ?!?!
  115. electrical probs
  116. Gotta decide what is best.....
  117. Timing issue
  118. Engine Rebuild on New Project
  119. Mass Air Flow Conversion
  120. Off Road Light Wiring?
  121. 87 22r miss
  122. Autozone idler arm castle torque
  123. 22re starter kits 28226-64370/-7407
  124. 22re bad stuck piston rings?
  125. Do I need new steering components, or is it all just BS?
  126. Anybody bought from The Toy Parts Barn?
  127. locker or no locker?
  128. Installing SR5 clock in my pickup. help
  129. R134A Condenser VS R 12 ??
  130. Rough idle on first Toyota: '87 4x4 22r /w Weber Carb
  131. Fan Clutch & A/C part 2
  132. 89 22re no power? code 52
  133. 87 4runner died
  134. 1987 4Runner SR5 5spd - It begins.
  135. 4runner camper
  136. 3VZE Engine: Please help identify possible oil leak? Near oil filter/water pump
  137. 95 4 runner popping out of 1st
  138. 95 4 runner back window won't go down
  139. 95 4 runner changing belts
  140. I cant remember
  141. Tachometer and Coolant Temperature Gauge acting erratically?
  142. Propane Setups
  143. New engine or reman?
  144. 3VZE - Code 25 + Check Engine Light Near Ocean Air
  145. 92 Toyota Pickup 22re - Starts up, wont' stay running, touch gas and it dies
  146. Head Bolts - Which to purchase
  147. how to attach spare to 4runner roll bar ?
  148. Help!! 86 4runner runs like dog crap in 3rd gear
  149. 6in IFS lift opinion.
  150. w56 Transmission Bellhousing Bolts Missing
  151. 3rd Row Leather Seats in 93 4Runner
  152. Lower Control Arm Camber Adjusting Bolt for 86 Pickup
  153. Code questions
  154. 4Runner Wing window, and power mirrors.
  155. Exhaust Mods....How Loud???
  156. 93 Rear Anti Lock idiot light is flashing
  157. Backfire on Decel, Then Floods
  158. starting problems
  159. Two Part Specific 22RE Header Question
  160. Idle "lopes" ONLY at around 2100 RPM
  161. 87 4Runner SR5 Restoration - Couple ??'s, Tires and Zuk Mod
  162. rear sliding window 92 truck removal?
  163. 1989 4runner V6 headers/trans cooler
  164. Power up my 3vze 4runner
  165. 22re engine turns over but will not start
  166. HELP CEL 41 and 22
  167. o2
  168. 87 4runner no throttle response
  169. 1st Gen 4Runner Color ?.
  170. Can you ID this connector? 22re
  171. Rpm wont reach 3k
  172. A note about spring coil compressors
  173. 3.0L heads
  174. Want to check my rpms and adjust idle
  175. 3.0 spark plug wire loom
  176. compatible axles?
  177. Fabricated hood scoop?
  178. 1988-92 3vz-e timing belt install
  179. Post Your 89-95 Yota Desktop Backgrounds
  180. CEL trouble
  181. installed my roll cage, headers, and ipf off road lights on the red beast..
  182. 88 3vze injectors wont fire
  183. Get the Most out of your 3VZ-E
  184. rod knock?
  185. V6 lift on a 22re
  186. Horn Relay Location [picture]
  187. 93 toyota pickup 22re auto to manual
  188. Another 3VZE overheating
  189. 91 22re fuel issue
  190. Help with flush a/c system
  191. New Distributor - 22r only advances 5 degrees!
  192. 5.71 gears and 8 inch spool?
  193. 4runner body on xtra cab frame??
  194. 1987 4Runner
  195. Factory Cam Sproket Paint Marks
  196. 91 pickup givin me the shake at freeway speeds 4/5th gear
  197. Help!!grinding noise! Rear end gurus please read..
  198. 94 4runner smokes/low on power
  199. 22re drive belt balance - A/C - crankshaft?
  200. 3vze starter repair
  201. need help figuring out why my '91 3vze won't run
  202. Steering Wheel Noise? (video)
  203. Timing way off 3vze
  204. 22r overheating - water pump or radiator?
  205. Gas Tank Relocation Mod
  206. engine swap now clutch wont dissengage
  207. Where does this yello/black ground wire go?
  208. 22re to r150f help
  209. Turbo or charger give me your opinions
  210. Case Oil Treatment
  211. 2nd Gen 22RE transfer case, is it the same as the 3VZE?
  212. Brake line routing
  213. 3.0 A/C question.
  214. Another 3.0 no start
  215. Gear Question (multipule donor vehicles)
  216. Where does this wire at the fuel rail go?
  217. 93 Toyota Pickup, hazard/signal problem
  218. Speedo Adjust and a Code 42
  219. 91 A340H in my 95 4Runner
  220. 4runner starts every once in a while
  221. 22RE won't idle at all
  222. lowering pics?
  223. 22re Finally bit the dust
  224. 3 digit CEL codes on a 93 22RE Pickup
  225. Ball Joint spacers and 63" chevy springs
  226. 93 p/u loss of power at low rpms
  227. 1991 4runner Timing Problems
  228. Cone washer 8mm or 12mm
  229. Axle from 86 4x4 22re ok for 95 4x4 3.0???
  230. 3vze help - bangs out at 1800 rpm (new tps)
  231. New yota owner
  232. new shock absorbers & ZUK mod?
  233. 22re missing and bogging need help plz
  234. 3vze Engine Pull Help
  235. 1994 door check
  236. Rear axle locking after being in 4x4??
  237. 87 22RE rebuild_ starting issues
  238. 88 yota Need some help
  239. Trying to drop manual transmission?
  240. A little help with no go. (will not starting or turn over)
  241. New gears and ARB locker
  242. Help ID Part for me?
  243. Modified, cut or custom fenders. Please post pics.
  244. Front input Bearing help!
  245. having trouble finding information
  246. RTV for locking hubs?
  247. Wiring Harness for Speed Sensor
  248. 86 needs box
  249. Advice on q 93 pickup tranny, hwat should I do?
  250. Correct way to install exhaust gaskets?
