88 yota Need some help
Old Jul 13, 2012 | 10:19 AM
claybrook's Avatar
What is this and whats suppose to be here? Could this have something to do with idle problems?
Old Jul 13, 2012 | 10:22 AM
waskillywabbit's Avatar
:wabbit2:
Old Jul 13, 2012 | 10:25 AM
SPARKS89's Avatar
Wow! That's your idle speed adjustment screw.....er, bolt. I would say it certainly could have something to do with a weird idle. Obviously somebody's done some adjusting to it before and If they put something like that in there chances are good they didn't know how to adjust the idle correctly.
It's supposed to look like that, circled in red.
Old Jul 13, 2012 | 10:30 AM
SPARKS89's Avatar
X2 wabbit.
seriously though, if they managed to use a bolt that was the same thread as the original screw and didn't strip it out or somehome mess up the threads you should be able to get a replacement at a junkyard for practically nothing...if they would even charge you for it.
although, it IS pretty original
Old Jul 13, 2012 | 10:55 AM
snobdds's Avatar
The bad thing is that is not a screw that can be ordered just by itself. The only way you can get a new one is through a junk yard or buy a whole new throttle body from the dealer.
I would try a junkyard first. Also, there is a rubber o ring that goes with it. If you can't find the o ring, napa has a metric o ring box that should have it.
Old Jul 13, 2012 | 03:16 PM
94_yota_4x4's Avatar
thats some interesting rigging
Old Jul 14, 2012 | 07:02 PM
abecedarian's Avatar
Sadly, that looks like an SAE grade 5 bolt driven in there, so the threads are buggered.
New TB time.
JonG85
Jan 18, 2023 04:31 PM
LittleUgly
15
Jan 2, 2020 01:30 PM
primordialbeast117
Dec 19, 2015 12:23 PM
Ditch Doc
Oct 27, 2015 03:20 PM
shredder4286
Oct 1, 2015 01:09 PM
