Diagnosis Vid: Will not go into gear!
Old Jul 22, 2012 | 10:06 AM
Toreador's Avatar
- New master and slave cylinders. Been bled. Will not go into gear.
- Pedals bracket has been fixed in past
In video
clip 1: bracket flex? as i push the clutch pedal, the ignition switch moves further away
clip 2: what is that leaking, electrical connection is wet? and clutch fork seems really loose? i can move it not only back and forth like that because the slave cylinder is in, but also up and down kinda. . .
clip 3: can you see what's wrong in this picture?
Any suggestions greatly appreciated
http://youtu.be/lAZI3KwYLWw
Old Jul 22, 2012 | 10:15 AM
swampfox's Avatar
Did you compare the length of the rods on the two clutch master cylinder ? I ran across a truck that had a rod that was a little short and the clutch wasn't fully disengaging.
Old Jul 22, 2012 | 10:48 AM
Toreador's Avatar
I did not compare them, but I have adjusted it. I tried it with the rod shortened as much as possible, the rod extended as much as possible, and the middle.
But question: do I have to bleed the system each time I adjust the rod?
Old Jul 22, 2012 | 11:57 AM
swampfox's Avatar
Once the system is completely bled you shouldn't need to it again.
norcal98
Aug 10, 2015 06:20 AM
JHalcyonM
Aug 4, 2015 01:19 PM
wolfpackfan33
Aug 2, 2015 03:36 PM
justdifferentials
Just Differentials
Jul 22, 2015 08:26 PM
rushw
Jul 18, 2015 01:46 PM
