93 pickup 3.0 auto to manual swap
ive been doing some research and plan on doing this swap pretty soon, i know ill need a clutch pedal assembly master cylinder flywheel clutch assembly hard line and soft line, and i know how to wire the harness to make the truck think its in neutral all the time, my only question is about the bellhousings, will a 22re bellhousing bolt to a 3.0 or will i need a 3.0 bellhousing to go to the r150f transmission, and also will my transfercase bolt right up to the back of the r150f? i plan on doing a write up as i start on this swap beings that i havnt been able to find one anywhere yet
Driveshafts are also a different length and the trans crossmember is different.
Bellhousings are different.
Is this a standard cab or ExCab?
About to do the same conversion but I already have my parts.
extended cab, i found an r150f with a bellhousing for 140. my t-case of the auto should bolt up to the manual shouldnt it? sorry im not very knowledgeable with toyota drivetrains never really messed with them much
Transfercases swap froma A340H to the R150F are not possible, Nothing wrong with the transfercase on the R150F.
You will have to replace the intermediate rear shaft or get it extended like 2"
TheManOutside
06-18-2015 03:32 PM
