93 pickup 3.0 auto to manual swap
Old Jul 25, 2012 | 09:54 AM
krkx93's Avatar
ive been doing some research and plan on doing this swap pretty soon, i know ill need a clutch pedal assembly master cylinder flywheel clutch assembly hard line and soft line, and i know how to wire the harness to make the truck think its in neutral all the time, my only question is about the bellhousings, will a 22re bellhousing bolt to a 3.0 or will i need a 3.0 bellhousing to go to the r150f transmission, and also will my transfercase bolt right up to the back of the r150f? i plan on doing a write up as i start on this swap beings that i havnt been able to find one anywhere yet
Old Jul 25, 2012 | 03:04 PM
Punchy's Avatar
Driveshafts are also a different length and the trans crossmember is different.
Bellhousings are different.
Is this a standard cab or ExCab?
About to do the same conversion but I already have my parts.
Old Jul 26, 2012 | 05:26 AM
krkx93's Avatar
extended cab, i found an r150f with a bellhousing for 140. my t-case of the auto should bolt up to the manual shouldnt it? sorry im not very knowledgeable with toyota drivetrains never really messed with them much
Old Jul 26, 2012 | 06:15 PM
Punchy's Avatar
Transfercases swap froma A340H to the R150F are not possible, Nothing wrong with the transfercase on the R150F.
You will have to replace the intermediate rear shaft or get it extended like 2"
Old Jul 27, 2012 | 05:40 AM
krkx93's Avatar
the only problem is finding all the parts, looks like ive got quite a bit of collecting to do
Goddamnboh
3.4 Swaps
12
May 11, 2016 09:22 PM
ZONAYODA
Jun 30, 2015 05:36 PM
1badyota350
Jun 28, 2015 06:50 AM
TheManOutside
Jun 18, 2015 03:32 PM
duckhead
3.4 Swaps
7
Jun 18, 2015 06:54 AM
