Front input Bearing help!
Old Jul 12, 2012 | 09:34 PM
91exCabYota's Avatar
Hello, my issue i need help resolving is:
I am in the middle of a head gasket repair, and i have my engine down to the block. My dad whos helping me thinks that it would be easier to do my clutch job by pulling the engine with a picker, as all thats holding the engine in is the mounts and tranny bolts. BUT: we also need to replace the front input bearing in the tranny. Is the Front input bearing doable without dropping the tranny? If not, we are going to put the motor back together and then drop the tranny, do the clutch + input bearing. Thanks in advance, any insight is much appreciated
Old Jul 12, 2012 | 11:20 PM
combatcarl's Avatar
Uhh..yeah? If you can see the input shaft in the bellhousing, you can do the input seal. Get the clutch fork outta the way, its right there. Gonna be sitting on the IFS to do it, but yep, I did mine before I found yotatech! Oh. Bearing. See, I did seal. Why the bearing? Trans issues before? Noisy-like? It should be fine.
Old Jul 12, 2012 | 11:29 PM
No shifting problems, just when in neutral or in gear with the clutch engaged a noise, hard to explain. Sounds like a bad bearing . Sooo will I have to drop the tranny to get to it? You didn't really answer my question
Old Jul 12, 2012 | 11:33 PM
combatcarl's Avatar
Heh. You're right. I think that may be a removal and split the case halves kinda thing. Any luck looking around here? I loaned out my book, so I can't thumb thru that right now...
Old Jul 13, 2012 | 12:50 AM
Ive got a Haynes, but I dont believe it goes into that much detail about tranny internals. Thank you! Still open to discussion if anybody else wishes to comment.
Old Jul 13, 2012 | 01:59 PM
Bump, can anyone offer any insight? I don't want to have to do extra work if i don't need too.
Thanks
88sasturbotoy
Jan 30, 2026 01:57 PM
mskalmus
May 28, 2017 07:51 AM
coffey50
Jul 28, 2015 10:55 AM
PlayAwhile
Jul 20, 2015 11:36 AM
dinks07
Jul 15, 2015 05:34 PM
