1991 4runner Timing Problems
Old Jul 13, 2012 | 10:15 PM
macneill5's Avatar
I am in the middle of attempting to get my 4runner timed and working properly. I have set the crankshaft to TDC, and set the top pulleys to the straight up. And when I start the engine up, it idles rough at around 500 rpms. Everything else is working, no leaks, spark plugs are new, spark wires are working properly.
When I line the bottom pulley on "0" my timing gun shows that it is past the 15. So I tried to set the bottom crank the distance it was off on the opposite side of "0". Stillbiant working... I am stumped, if you have experience doing timing please help.
Old Jul 13, 2012 | 10:18 PM
macneill5's Avatar
Best case scenario I would like to be able to replace all the parts involved, but I don't have the money to buy any unnecessary parts.. Thanks for the help..
Old Jul 13, 2012 | 10:54 PM
justin_4runner's Avatar
i would look over the manual real quick and also recheck that the dist is right,
http://www.ncttora.com/fsm/1990-1995...e/timingbe.pdf
Old Jul 13, 2012 | 11:15 PM
macneill5's Avatar
Thanks, I will take a look at it.
I haven't bridged the Te1 and e1 connectors, will that effect the timing being off?
Old Jul 13, 2012 | 11:58 PM
Mitchell12's Avatar
Yea, it could. That's how you should be setting the spark timing. Should be 6* or something but check your manual.
Old Jul 14, 2012 | 06:05 AM
scope103's Avatar
Don't confuse cam timing (set by the timing belt) with ignition timing (set by the distributor). When you install the timing belt, crank is at 0 and cam pulleys point straight up to the marks. Then you are done.
Once it's buttoned up, you use the timing light to set ignition timing. Yes, you need to jumper TE1 to E1. The correct setting (around 10 degrees) is on the sticker under the hood (if set somewhere else you won't pass smog). Point the timing light at the crank while running, rotate the distributor to get the mark in the right place.
Old Jul 14, 2012 | 06:42 AM
carlo082688's Avatar
right... set pulley to 10" before TDC.. check timing light on pulley and rotate distributor to set desired timing, the manual says 10" or 8" BTDC...
Old Jul 14, 2012 | 09:47 AM
bone collector's Avatar
what motor??
Old Jul 14, 2012 | 10:19 AM
scope103's Avatar
Originally Posted by bone collector
what motor??
Originally Posted by macneill5
... and set the top pulleys ...
I'm guessing 3VZE. Not that it matters much in setting ignition timing.
Old Jul 14, 2012 | 08:14 PM
macneill5's Avatar
I have set the cam timing properly, and then set the ignition timing with the distributor and timing gun...I set it to 10* while idling, but the engine ran rough at around 500 rpms. (In the manual I read from the above link it said while the te1 and e1 connectors are linked, the rpms should be 800 + or - 50* rpms.).
Thanks for the link to the manual it helped to understand the timing system a little bit better.
Old Jul 14, 2012 | 08:34 PM
abecedarian's Avatar
Was there anything in there about checking the timing and setting the idle with the engine at operating temp?
Old Jul 14, 2012 | 11:09 PM
macneill5's Avatar
Yeah, it says to get the engine to normal operating temperature. And then proceed to turn the idle speed adjusting screw.
It says that I need to have a tachometer plugged the IG connector, or would I be able to look at the tachometer on the dash? Sorry for the dumb question...
Old Jul 15, 2012 | 05:15 PM
macneill5's Avatar
Thanks for the help with the timing, it is timed properly, and running good according the link listed above.. I am now getting some hesitation when I step on the gas. If I press it slowly, I can accelerate with no problems, but when I step on the gas hard it sounds as though the engine stalls, and after a second or two it will accelerate.
I am thinking it could be something along the lines of either the air intake, or the fuel filter.. Does that sound right to anyone?
zd92655
Mar 6, 2022 12:58 PM
Aleeex_u
Jun 5, 2016 06:52 PM
Ichneumon
Sep 27, 2015 04:21 PM
bprice0077
Jun 25, 2015 07:36 AM
ShaunKris
Jun 17, 2015 04:33 PM
