how to attach spare to 4runner roll bar ?
Old Jul 19, 2012 | 02:27 AM
swerks's Avatar
I know people are strapping these to roll bars but I need to see how its done. any pics would be helpful thanks. I have mine strapped back there but its always coming loose because it doesn't sit up flush to any thing.
Old Jul 19, 2012 | 03:34 PM
swerks's Avatar
Anybody ????
Old Jul 19, 2012 | 06:31 PM
XtraSlow_XtraCab's Avatar
I would just weld 2 wheel studs to the bar, the appropriate distance apart, and bolt the spare on with lug nuts.
You could also drill through the bar and weld a 3/4 " over the hole. Then buy a foot long 3/4" bolt to thread into that nut through the hub-hole of the rim and weld some flat bar to the bolt head that will screw tight against the tire... like how a trunk-floor mounted spare system works but horizontal.
It's probably not a very famous idea though, have you taken an entire load of passengers camping in a 1st gen AND carried all the crap? Space is limited and entertaining a large spare you may or may not use is not a welcoming option.
Not to knock your idea... that's where mine was at one point, but space is limited and you'll find out quick.
Old Jul 19, 2012 | 08:37 PM
wyoming9's Avatar
Red face
ratchet strap through the wheel tighten it up mine has been like that for years .
I check the air pressure in place
Old Jul 20, 2012 | 02:18 AM
swerks's Avatar
I have mine back there with a ratchet strap now, but I would like to see how people are running the strap, because the tire does not sit flush to the bar it keeps loosening up.
MMA_Alex
25
Apr 18, 2017 05:07 AM
shisha1999
Mar 16, 2016 12:25 PM
Sep 4, 2015 09:27 AM
