Rpm wont reach 3k
Old Jul 17, 2012 | 05:37 PM
Westly7's Avatar
Rpm wont reach 3k
My 22re been acting weird,starts up fine idles fine 1st 2nd 3rd gear fine but once starting to speed up at 2.7k ish rpm its like running out of gas or running lean,when i hit gas all the way the rpm will go up VERY slowly and u can feel engine is shaking that makes car shaking too and my rpm neddle like having an eathquake just to reach 3k rpm.
But its not happened on 1st or 2nd gear.
Im guessing either spark plugs/wire/rotor n cap but not sure
New oem fuel filter less than 6mo
Spark plugs in their way.i need some input where the cheapest deal to buy oem plug wire,rotor n cap? If anybody can direct me
Old Jul 17, 2012 | 05:40 PM
sechott's Avatar
You may have weak valve springs.
Old Jul 17, 2012 | 05:44 PM
sechott's Avatar
Just a thought if you can get a hold of a vacuum gauge you might be able diagnose your engine.
http://www.imperialclub.com/Repair/F...auge/index.htm
Old Jul 17, 2012 | 05:59 PM
Westly7's Avatar
Is it weak valve springs a commOn problem for 22re? Mine only 155xxxmileage
Old Jul 17, 2012 | 06:10 PM
sechott's Avatar
It can be a few different things or a combination. But, not able to get high RPMs under load is a valve spring symptom.
Old Jul 17, 2012 | 06:14 PM
Westly7's Avatar
Hmm im gonna look look for sign or symptom of weak valve springs when i get off work,thanks for input
Old Jul 17, 2012 | 06:27 PM
nothingbetter's Avatar
with my engine, your sypmtoms are what happened to me with a wrecked air flow meter/mass airflow sensor.
Old Jul 17, 2012 | 07:21 PM
abecedarian's Avatar
Check and set your idle speed and timing.
Check for vacuum leaks, in particular in the duct from the throttle to the air filter.
Check your spark plugs; check your plug wires- make sure they're not close to any metal.
Old Jul 17, 2012 | 07:46 PM
Westly7's Avatar
I checked timing like long time ago it was correct.
Vacuum leaks will messed up the idle too right? But my idle just perfect
Spark plug might need replace thats why i ordered already,wires no loom might touching any metal and very close to header
Udated i just revved on 2nd gear and it happened on 4k rpm *sigh*
Old Jul 17, 2012 | 07:47 PM
arlindsay1992's Avatar
I seriously doubt it's valve springs. My 22RE Runner had 295,000 miles and ran fine minus burning large amounts of oil. Unfortunately the remanufactured motor burns oil and coolant, so I'm building the next motor myself. But that's a different story.
Old Jul 17, 2012 | 07:53 PM
combatcarl's Avatar
Once you've eliminated simple things, check your TPS, most Haynes or Chiltons manuals even have the specs. You'll need a multimeter, to check resistance through the circuits.
Old Jul 17, 2012 | 08:08 PM
4Crawler has specs too.
Old Jul 17, 2012 | 10:22 PM
Westly7's Avatar
I hope its not the valve springs, im moving out in 2week and i still have to finish this and swap tranny or my 240sx
Old Jul 18, 2012 | 03:45 AM
SPARKS89's Avatar
I don't understand how it could be an engine problem if you're not getting the same results in all gears.
You said it doesn't do it in 1st or 2nd gear, but it does it in 3rd. That's a little weird to me because 1st and 2nd will obviously reach 3k RPMs easier than any other gears. I wonder if it's something with the transmission rather than engine. Try revving the engine sitting in your driveway up to those RPMs and see what you get. I'm going to assume that you have a 5 speed (you didn't specify) so try it with the clutch in and out and see if that changes anything. What about 4th and 5th gears....does it do the same thing then too?
Old Jul 18, 2012 | 04:51 AM
Westly7's Avatar
I just revved on 2nd and 3rd last night and it was happened but in higher rpm (4k) basically .if the car just sitting and i hit the gas,rpm will go up freely.yes mine is 5speed sorry.
So 2nd n 3rd gear happen to but around 4k rpm and 4th n 5th gear on 2.7k rpm
Old Jul 20, 2012 | 08:14 PM
Westly7's Avatar
Problem solved by new ngk spark plugs!! Thanks
Ditch Doc
Oct 27, 2015 03:20 PM
shredder4286
Oct 1, 2015 01:09 PM
voiddweller
Sep 28, 2015 11:21 PM
drifttruck
Sep 18, 2015 11:19 AM
Mrfobbyaccent
Sep 10, 2015 12:13 PM
