Propane Setups
Old Jul 20, 2012 | 04:28 AM
yotarover's Avatar
Propane Setups
Need some insight on setup. Non streeter,22re auto. what'd you guys leave in *wiring hardness wise and what'd you change* can you retain the starter, alt and lights w.o the ecu or is it required? if it is i'll just rip out everything including the dash.
No smog no emissions.
Been reading, all i've seen is turbo setups but nothing about the wiring related parts.
Old Jul 20, 2012 | 06:35 PM
abecedarian's Avatar
Something to consider about propane on an RE is that the ECU controls everything about the engine: injection, timing, et al. Going to propane means ditching most everything in the engine bay connected to the computer.
It's not a simple swap by any means.
Old Jul 20, 2012 | 07:39 PM
yotarover's Avatar
I know, my ecu is dead anyways. it's simple if your willing to get rid of all the efi crap. I just need to know what isn't controlled/ doesn't rely on the ecu to work. Other words if I have to run a new fuse block or alter the stock one. To rewire my starter,alt,ign,and lights so be it. I'm just trying to see what other have done.
I've already bought a new carb dist and coil.
Old Jul 20, 2012 | 07:42 PM
yotarover's Avatar
Guess I should have asked , Pirate. But this seems like a newbi question.
Old Jul 20, 2012 | 07:43 PM
Pull the ECU wires from the kick panel and cut them. Fish all of them back through the firewall and cut every one of them.
Hopefully, you'll be left with the chassis wiring you need to operate the dash- temp gauge, fuel... won't need that with propane though ,
When you get near the igniter, you may want to skip some of those since they get power from the key.
Honestly, I'd suggest getting the FSM for the truck and trace them all down. I don't think there is a definitive guide for what you're looking for... at least there's not one here on YT. One of the other boards may have more 411.
Old Jul 20, 2012 | 08:11 PM
yotarover's Avatar
That's more like it. Got the fsm just haven't taken the time to print the wiring from the pdf file. The only things i wanna keep are the head,tail,brake lights,signals,heater,temp gonna need the normal starter,alt,ign. everything else related to the 22re is getting unhooked. then i'll wheel the ifs this way till it breaks, sas it and keep going.
Old Jul 20, 2012 | 08:15 PM
The chassis wiring is siamesed with engine wires under the hood sand dash so be ready for cutting some looms.
Old Jul 20, 2012 | 08:32 PM
yotarover's Avatar
I noticed that's part of the whole reason for asking.
Old Jul 21, 2012 | 10:27 AM
yotarover's Avatar
got my wiring hardness out uncut and unhacked, just took out the whole dash and loosened up the intake and uncliped the injectors. hardness is for sale in the parts section( for those in need of a 86 hardness with fuse blocks. ready to plug and play)
Quick question this hit me after i got the hardness out. Will the a340h still shift normaly?
Old Jul 21, 2012 | 11:23 AM
yotarover's Avatar
Nm, that Got the answer I needed.which is go with a Rad Designs RailII shifter.
Old Jul 22, 2012 | 09:49 AM
yotarover's Avatar
Anyone running pane and setup, your wiring from scratch? Right now my whole hardness is outta the truck. need some idea's on wiring up the Alt,Starter and I think i'll go with a switch and push button for ign. I'll leave out the lights till it's all running and driving.
Old Jul 25, 2012 | 11:55 AM
yotarover's Avatar
For those of you venturing into Propane. And are willing to run fresh wiring etc, here's a simple diagram (I take no credit for this as it belongs to Sirmarion on pirate)
All relays are 30amp. This will get you up and running.
kawazx636
Oct 6, 2021 03:03 PM
4runnerFireman
Sep 29, 2015 06:24 AM
voiddweller
Sep 28, 2015 11:21 PM
Keithstoyota
Sep 27, 2015 07:29 AM
