Steering Wheel Noise? (video)
Old Jul 15, 2012 | 07:06 PM
xylicon's Avatar
Question Steering Wheel Noise? (video)
This noise starting happening within the past week, I cannot figure out exactly where it is originating from. Has anyone else experienced this and been able to fix it?
The sound is coming from inside the cab.
http://www.youtube.com/watch?v=hAExt...yer_detailpage
Old Jul 15, 2012 | 07:31 PM
combatcarl's Avatar
Ha! Yeah, mine kinda does that, too. Sounds a little like PS pump on an old Ford truck, but right behind the wheel. Ya gotta take the wheel off, and put some electrical contact grease on the ring that the horn contact follows. Pretty simple, I just haven't done it.
Old Jul 15, 2012 | 08:39 PM
NickMiller's Avatar
Yea, I had the same problem... It's just a bit of rubbing on that horn contact. No big deal.
Old Jul 16, 2012 | 08:03 AM
arlindsay1992's Avatar
This problem goes along with the horn that only works in certain positions of the steering wheel. Fix is remove the steering wheel, clean off old dried up green grease, sand the copper contacts, and apply new grease.
Old Jul 16, 2012 | 10:50 AM
xylicon's Avatar
Seems like an easy fix, thanks guys. Now my next question is about removing the steering wheel, I have the Toyota FSM for my truck but it does not mention how to remove the pad from the steering wheel, I am assuming I can just stick a straight screwdriver in there and it will pop out? I don't want to mangle it by prying.
Old Jul 16, 2012 | 10:57 AM
MaK92-4RnR's Avatar
sounds like its rubbing on the plastic... who cares.
Old Jul 16, 2012 | 11:35 AM
NickMiller's Avatar
DON'T pry it... There are screws on the backside that you have to take out (3 of them). After you take the screws off, THEN you can pry it off carefully. There are wires that disconnect for the horn that you probably don't want to break... lol. I can snap a pic highlighting the screws if you need me too. It's pretty self explanatory though.
Old Jul 16, 2012 | 06:40 PM
TrikeKid's Avatar
Yup, sounds just like mine with some beat up plastic around the column. I don't have another set of tilt column plastic, and the rest of the truck is usually loud enough that I don't hear it, it's not hurting anything.
terminator
Jul 27, 2015 07:13 PM
PlayAwhile
Jul 20, 2015 11:36 AM
razorman8669
Jul 12, 2015 12:13 PM
mlavery85
Jul 12, 2015 10:33 AM
