- spectre intakes on 22re
- Need Help w/ Preventative Maintenance
- 1990 4X4 22RE 95K miles no power
- I think it my starter is giving out
- My 86 4Runner (56k death)
- New '94 4Runner Owner Pondering
- Tires finally on the way!
- 1988 Toyota xtra cab thread
- 22re starter nut size
- Can you identify these 22RE parts?
- CV issues
- How do I get a seized bearing race off the spindle?
- What is this, and should it be plugged in?
- Cleaning Evaporator Coils/Drain Plug
- Help!!!!! me fix my leaking problem...
- Blinker issues
- 340H transmission question
- Kitting out with new pro comp gear, need help
- BIG idle differences between Park & Drive
- Rear window?
- beastly distributor 90' 3vze
- Adding AC to my Pickup
- Missing Fuses?
- M/T Classic II wheel sizing
- Passenger window stuck closed
- roof top tent?
- 94 3.0 v6 vze engine timing chain
- Easy Fix for Spare Tire Winch - Carrier
- questions about 91 3.0 starter
- '94 Rear Deck Window Prob
- Question about my cams
- exhaust recomendations
- Power rear window mod
- 22re lower intake removal
- Torsion Adjustment Bolt Size?
- bad valve seals?
- Fuel pump problem
- Getting the 22re rebuilt
- Driveshaft + rear diff. problem
- help clutch replace
- I need some advice on an '86 custom cab
- 1992 pickup 22re hand held tach question
- metallic noise in rear?
- Catalytic Converter
- Thinking of a 2nd Gen project
- Old School Differential Training Video
- Oil pan FIPG removal
- Leaking Coolant from Rear of engine, Firewall area?
- recommended ball joints?
- Where To Get Rear Diff Casing Bolts
- 93 4Runner
- Blew up another 3vze
- Silicone Vacuum Hoses illegal?
- 1uz Started !!!!!!!!!!!!!!!!!!!!!
- $60 from new toyo tires
- Pick up my first 4Runner late this afternoon
- 22re truck idling weird
- Rebuilt Motor Barely Passed Smog?
- Wheel bearing repack without bleeding brakes?
- 86 pickup with several issues
- power window's and locks
- this is so depressing...
- 2007 FJ Cruiser coils on 93 4runner
- need rear spring substitute
- help with running hot
- Auto transmission-stay away?
- 3vze Help
- Coolant Temp Sensor
- rubber piece on top of transmission
- Fun with steering gear box replacement
- vacuum lines diagram under hood?
- Heating up under load but not overheating
- 92 V6 4/Rnr Surges When Hot!
- Burning oil and leak-down test results
- Just scored 4runner buckets! Real quick ?
- OEM toyota shocks?
- New Shocks for my 94 pickup?
- IFS lift
- Rear Coil Spring Spacer problem
- Rear axle vibration
- gas tank question
- 5 speed swap or replace auto?
- what seats fit?
- Hi Flow Cat Converter Question
- Can u help out identify this lines
- Very tough dent!
- What is this?
- What is it worth, anyone interested?
- 2nd gen center cap question
- 86 22RE Hesitation issue
- Toyota Intake Meter
- The motor cranks, just wont start
- Transmission issues
- head differences??
- Just bought 85 truck extended bed
- Shocking
- TBI v8 into my 89 runner?
- Truck only starts with clutch start button
- 3VZE High Idle Fix
- speedo not working
- 87 22r not timing chain not moving?
- Leak problems.
- is there a way to mount a new seat on my own rails?
- Taking grille off/headlight replacement
- transmission fluid?
- Cracked dashboard
- hesitation? fuel pump? TPS?
- cam replacement?
- Diag code 14
- Anyone with an auto tranny......
- 92 TOY's 22re / crapped out / gotta start somewhere / thread
- Light Wiring Question...
- Is the frame hardened steel or just regular steel?
- Carburetor Problems
- still overheating after new radiator
- Need help getting reman 3vze to run right
- Brakes gradually get stiffer and stiffer, hardly any pedal play
- 4runner differential mystery, need help.
- center caps dont fit
- 93 22re cranking problems
- stripped t-cover bolt?
- bench seat covers?
- 22RE bottom end inspection/ cold start rattle
- 85 to 86 22r cyl head?
- SR5 gage swap - had to re-wire connector
- 90 4runner needs your help
- Air in and air out- Intake to exhaust question
- 22RE Idle Gremlins
- Bad master cylinder?
- complicated or straightforward?
- *Update* NEW MEATS
- 94 4runner damaged!?
- Blower
- 2" or 3" leaf springs?
- New 94 Pickup owner Introduction
- Power Seats
- replace alternator 94 4runner
- windshield rust repair begins
- 1990 4 runner rolled
- Third brake light on a 1st gen 4Runner
- 2 x 12 inch subs in the extended cab. good idea?
- Bolts on rear of rotor.
- Starting problem ( need help )
- Bad motor Mount??
- Post Head gasket job, now scraching my head
- 95 3VZE Overheating???
- Needed: Vac Diagram for '90 22RE (Cali) AT, AC
- New to me 87 4Runner
- break into rear doors using slim jim
- 22r head gasket
- 3ZVE fuel pulsation dampener
- Drivers side frontend motion
- 3vze starting and running issue
- New to lockrite
- Alignment after BJ spacer install
- Popping sound after BJ install
- Hood alignment issues??
- Loose steering, what parts should I replace
- Low Fuel lamp on with a full tank
- Brakes & Rotors, what else?
- Rear End issue?? Jerks while backing up Spool Rear
- will any bodyparts from a 86 fit on a 94???
- Need help reading Smog Test Numbers -- 93 pickup
- Topless (And poor little JEEP)
- Newb DIY overhaul??
- Water pump impeller Wore through the back plate and now serious coolant leak
- 1993 truck 4x4 rear end
- Hella 500FF Installed + PICS
- Speedo suddenly broke, whats goin on?
- rear anti lock problem??
- Grinding from Front Left Wheel
- Clicking when gas is pressed
- Deflector on Halfshaft
- strong fuel vapor smell (90 3vze)
- Fan switch runs on high only
- Should I? (Rust Related)
- 87 SR5 Ugrades...
- 4runner parking brake question....
- Starter Leaking Green Stuff?
- got ahold of 1985 SR5 buckets and they are INSTALLED!
- 3.0 Almost finished, but what are these wires...
- Puling block on 22re pickup
- Alternator grounded out - blown fuse?
- are the lead cones that hold the front hub assembly on reusable?
- 1st gen what would you do? (engine rebuild question)
- valve shims/Mossy Toyota Sucks
- Whats a good clutch for a 2wd street truck?
- engine code help
- My PCV valve nightmare!
- 22re Rebuild Video
- 1st gen 4runner suspension questions.
- Gaargh! toasted another alternator...solution?
- toyotas gear ratios.
- '92 V6 4/Runner surging and losing power
- IM BACK!! and with pictures of my engine rebuild
- Water pump shaft pushed back?....
- harmonic balancer sleeve does it work?
- New parts! The SR5 conversion is almost done.
- windshield rust and re seal questions
- Best head gasket for a 22re turbo?
- Newb with a towing question
- 1988 Toyota 22re EFI has starting problems please help
- Charging System
- Horrible noise from the front end
- NEW 3VZE or REBUILD @ 200,000 or swap in a....
- Driver's Side Mirror: Wobbly Glass
- Clunking vibration when turning?????
- 3VZE Power Steering Brackets
- 3vze air conditioner questions
- Hard to Start, Timing Issue Write Up
- 1st Gen 4Runner mirrors upgrade.
- Please help no power at 55 mph or in fifth gear
- a very tough choice to make..
- need help
- i got an 89 sr5 and im wonderin if an intake system is worth it
- Bad Oil Pump
- High flow cat vs. straight pipe
- Fuse box 87 toyota 4x4
- clutch torque specs?
- Reed valve wiring
- Old Mod, Different set up
- My "New" 95 Extra Cab 4x4
- A/C system won't take freon..Compressor clutch engaged.
- stuck valve...
- Odd starting problem - bad plugs?
- questions on 89 2wd body lift
- Need help identifying some wires/cables
- 4" lift and drop pitman?
- Need help. Bogging/Sputtering out.
- body of my 89 sr5 rotted to hell, any tips?
- 87 22r overheating
- Bolt at End of axel
- Sticky injectors?
- Trans mount bolts
- 1989 toyota 2wd pick up lift
- 88 4runner stumbles on take off
- Wheel Spacers, Ball Join Spacers, Downey Springs
- 22re valve tick- 35K miles
- Maybe the clutch is going?
- Did I toast my tranny?
- Timing advancing
- fuel inj. onto carb motor
- By my hand or not??
- Misfiring popping and a code 12
- searching for turbo still
- 3.0 years
- Soft Top Picture Request
- 3vz gas mileage
- Head Gasket or Rebuild?...
- No pressure in gas tank
