Fuel pump problem
Old Aug 11, 2009 | 02:57 PM
alaskapilot21's Avatar
Fuel pump problem
I have a 91 toyota pickup 3.0l and when I crank the engine, I am getting no fuel through the lines. I took a meter and plugged into in the fp connector and show current when I crank. I also connected a battery straight to the fuel pump connector and got fuel to flow. One thing I found odd is that when I connect a meter to the wires I find that both wires from the fuel pump show resistants when grounded to the truck. The ground wire from the fp should do that obviously but why would the power wire show that? But again, I did get fuel flow when connecting a battery straight to the fp wires.
Old Aug 11, 2009 | 03:12 PM
INFINITY's Avatar
do a search for "factory service manual"
use the under hood jumper in the cluster of pins by the fuses. try your relay and check all fuses.
smthwsn357
May 1, 2024 07:28 AM
Charecter1
Nov 6, 2023 10:08 AM
jbv808
Aug 6, 2021 04:47 PM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
