Needed: Vac Diagram for '90 22RE (Cali) AT, AC
Old 08-06-2009, 03:50 PM
qdude79's Avatar
Can't find it. Sticker under the hood is way faded. Any help would be appreciated. Under hood shots of said vehicle would be optimal. Much thanks!!
Old 08-06-2009, 07:38 PM
desertcamper67's Avatar
Show us a picture of the area you are having trouble with and I'll send you a pic of mine. Probably very similar.
Old 08-07-2009, 08:17 AM
qdude79's Avatar
Ok, here's some pics I got this morning.
Note: I unplugged the lines that went from my power steering idle up connection, 'cause it didn't do anything but drop my rpms a bit. I realize the line I routed back from the intake to the idle up valve is wrong, but I didn't have a cap on me at the time. Also, everything else is as I received the vehicle, no changes. One thing I do note is that my AC idle up valve does NOTHING. I've replaced both the valve and the actuator, and verified that the actuator fires. Nothing. Screwing in the plastic adjuster does nothing, but if you pull it out completely it causes the major vac leak and kills the motor. This I do not understand...
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
montanatruck
02-26-2017 07:07 AM
yipyip45
12-02-2015 08:16 PM
RobotMoose
09-02-2015 05:53 AM
tomczaksdiesel
07-26-2015 10:35 PM
Quick Reply: Needed: Vac Diagram for '90 22RE (Cali) AT, AC
