93 22re cranking problems
Old Aug 7, 2009 | 03:26 PM
93YotaMonster's Avatar
hey guys i drive a 93 toyota pickup 4x4. here latley wen i go to crank it, i have to hold down the gas like a carburator to get it to crank. my check engine light is on and the codes are 2 an 5 anyone now what they are? and it smells like its running rich.
Old Aug 7, 2009 | 03:36 PM
toyota4x4907's Avatar
Well there is no code 2 or 5 for a '93 22re, but there is a code 25, which is lean mixture.....
The lean mixture is obviously why you have to hold down the gas pedal. Since you're smelling gas, bit bet you're leaking somewhere.
Old Aug 7, 2009 | 03:43 PM
oh well thats how many times the check engine light blink'd. well its not running lean its smells like its running rich. and the idle has ben kinda low, ive adjusted it and it hasent changed anything
Old Aug 7, 2009 | 03:57 PM
Its running lean. if it were running rich you probably wouldnt have to hold the pedal down. With the CEL light, it flashes a number (2 in this case) short pause ( maybe one second) then the rest of the code (5). then a longer pause. It will then either blink for a different code or loop back and blink the same one again if no other code is present. For future reference, '88 and newer there re no single digit codes for the 22re.
Old Aug 7, 2009 | 06:57 PM
ok so how will i fix it if its running lean? and yeah it does flash just like you descibe, so if you ad it up what would that code be
Old Aug 8, 2009 | 07:20 AM
It would be code 25.... You dont add up the numbers, you "put them together". The first series of flashes is the first digit (in the 'tens' place of a double digit number, in this case 20) then the second number is the second digit in a double digit number, in this case 5 (in the 'ones' place of a double digit number. Put those together and you have 25, which is code 25 which is lean mixture . There are a lot of things that can cause lean mixture: Bad O2 sensor, leak in the exhaust, leaky injectors, low fuel pressure, bad AFM, ignition system (plugs, wires, cap rotor, coil, etc.) open in injector circuit, engine coolant temperature sensor. There may be a few more so start looking.
Old Aug 8, 2009 | 07:27 AM
ok i understant its a code 25. but thats a lot of stuf to check on. it has a new IAC, plug wires,coil,cap,rotor button, whats a open injector circuit, and how do you check the afm?
Old Aug 8, 2009 | 08:02 AM
AFM testing, per 4crawler: http://www.4crawler.com/4x4/CheapTricks/AFM/index.shtml
Old Aug 8, 2009 | 08:06 AM
ok thanks for the help.
bigjstang
Jun 2, 2025 03:56 PM
sandyota
Feb 4, 2021 11:16 AM
redneck17
Jul 17, 2015 07:44 PM
Poncho0206
Jul 10, 2015 06:21 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
