Bad Oil Pump
Old Aug 2, 2009 | 07:34 PM
myyota's Avatar
Bad Oil Pump
The oil pump on my truck died and it chewed up the the gear that slides over the crank shaft that drives the oil pump, were can it get this gear, and my next question is, would using a used oil pump be ok or should i buy a new oil pump ?.
Old Aug 2, 2009 | 07:50 PM
vital22re's Avatar
totally a bro
if you buy a new pump it should come with the gears
Old Aug 2, 2009 | 08:07 PM
myyota's Avatar
The gear that im talking about slides over the crank shaft, and then the oil pump with its gears slides over that gear and drives the oil pump.
Old Aug 2, 2009 | 08:08 PM
vital22re's Avatar
totally a bro
or right.. gotcha... maybe find one of those used... otherwise.. dealer...
Old Aug 2, 2009 | 08:15 PM
myyota's Avatar
Originally Posted by vital22re
or A.. gotcha... maybe find one of those used... otherwise.. dealer...
I hope i can find a used one somewere, im sure the dealer would be very expensive, damn, if its not one thing its onother.
Old Aug 2, 2009 | 08:47 PM
Jay351's Avatar
Find somebody parting out a truck. You can get a bad 22re (if you can find one) for cheap.. Like A few hundy. Then you got tons of spare parts, or you can sell parts..
Or just buy the oil pump drive splined gear from a bad motor.
Old Aug 3, 2009 | 04:57 PM
iamsuperbleeder's Avatar
http://www.toyotacatalog.net/M1WebGe...B-215139B77B41
Old Aug 3, 2009 | 05:07 PM
Junkers88's Avatar
I'd say pull a junkyard oil pump and check the tolerances. If it checks out then buy it and install it, if not then pull another one and do the same until you find one that checks out. Be sure and buy a gasket set.
Oil pumps off of our engines out here go for 7.50$ a shot. You can do a lot of looking for that amount of money and the time it takes to pull one.
Old Aug 3, 2009 | 05:22 PM
myyota's Avatar
Originally Posted by iamsuperbleeder
Thanks superbleeder, i just placed an order.
Old Aug 3, 2009 | 06:35 PM
myyota's Avatar
Ok, everything is ordered, new spline gear and oil pump, about 150.00 for everything, and it should be here by this friday.
bigjstang
Jun 2, 2025 03:56 PM
sandyota
Feb 4, 2021 11:16 AM
Sep 4, 2015 09:27 AM
jakebarrett
Jul 10, 2015 07:15 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
