By my hand or not??
Old Aug 1, 2009 | 09:07 AM
DeGOAT!'s Avatar
By my hand or not??
So... for the past year, my '88 4runner's 22re has been developing a bunch of ticks, odd noises, and leaks, and from the way that it's running, I don't think it could be putting out more than 90hp.... It's on its way out. So I've been researching rebuilds and how to rebuild the 22re, and am now at a fork in the road. I was thinking that if I was going to rebuild it, I would try to get as much horsepower out of it as possible.... So here's the question.
On the one hand, I could get another 22re swapped in that would be built for me by these mechanic guys in Oceanside that only work on 22res all day. For $1600, I can get a mechanic estimated 145 hp with it bored 40over, mild porting stage 2 cam, stock valves, header, head, clutch, oil pump, water pump, gaskets, labor, tune up. That also includes the install.
What I was going to do is us ENGNBLDR's Street RV Head and rebuild kit with the 261 cam, oil pump, and timing chain with driver's side steel rail. I was also going to have the block bored 40over and the crankshaft turned, and buy the 1600lb mc hd clutch kit. I was also going to give it a tuneup.... If I do all the work myself, it'll all come out to be about $1500.
I value you guys' opinions, so let me know what you think I should do. I really would like to finally have a nicely running engine that might pull a small tent trailer around because my fiance really doesn't like to sleep on the ground.... :/ Does anyone have the same setup as what I would do, or does anyone have an estimate on the power output for that one? Thanks a lot in advance!
Old Aug 1, 2009 | 09:16 AM
JShaffer0525's Avatar
the first one sounds like a steal. i recently dropped in an $800 junkyard engine and spent close to another $800 in other parts and did all the work myself. Let them do it, save yourself the headache.
Old Aug 1, 2009 | 11:11 AM
toyota4x4907's Avatar
IF you feel confident that you can do the work correctly and that you don't mind not having the vehicle to drive for a while then do it yourself. Read over IAmSuperBleeder's 22re rebuild thread if you havent already. Thats a dang good thread. Of course there are others, but thats the most recent and is pretty in depth. Personally, I would do most of the work my self for a learning experience. Of course I couldnt do the machine work like boring and turning the crank because I have no machines like that. Make sure you get all the necessary tools, guides, parts, etc and you should be good to go
kawazx636
Oct 6, 2021 03:03 PM
coryc85
Dec 5, 2015 08:42 AM
SpookyMulder
Nov 4, 2015 11:56 AM
alexcarey
Oct 14, 2015 06:05 PM
JamesDINAN
Sep 22, 2015 05:37 AM
