cam replacement?
Old Aug 8, 2009 | 11:22 AM
yoterr's Avatar
cam replacement?
ughh another quick question for peace of mind....im buying a head without a cam in it, whats all involved with swapping my cam over to the new head? unbolt and bolt? new cam bearings?? thanks for the info guys been askin alot of questions lately and all have been answered mad props
Old Aug 8, 2009 | 12:52 PM
pntbol11's Avatar
i would definitely recommend micing the cam journals to make sure they are in spec. If they are just put some new cam bearings on it.
Old Aug 8, 2009 | 12:55 PM
yoterr's Avatar
so technically i can just bolt it up? just not recommended?
Old Aug 8, 2009 | 03:05 PM
yoterr's Avatar
???bumpidy???
Old Aug 8, 2009 | 04:47 PM
854x4's Avatar
There are no cam bearings on 22re's. To check the clearence put the cam in use plastigauge and bolt down the caps then unbolt and check the clearence. If you dont want to check clearence just bolt in your cam and make sure it spins smoothly. Make sure you lube the cam when you do the final install. Also you cant swap the caps that hold down the cam to a different head or you will run into problems.
Old Aug 10, 2009 | 06:18 AM
pntbol11's Avatar
My bad, that came from a guy who's never pulled a cam out of a toyota, lol You learn something new everyday.
bigjstang
Jun 2, 2025 03:56 PM
thefishguy77
Jul 30, 2015 10:59 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
1994toyota
Jul 17, 2015 03:03 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
