Clunking vibration when turning?????
Old Aug 3, 2009 | 06:24 AM
djrazr's Avatar
Unhappy Clunking vibration when turning?????
On my way to work, on even slight turns i was feeling and hearing a lound clunking sound, and the truck would vibrate. When i'm going straight, it's fine. It scared me, but i made it work safe
Where do i start?
Thanks
95 4x4 SR5
Old Aug 3, 2009 | 06:30 AM
dropzone's Avatar
Fossilized
bad CV
Old Aug 3, 2009 | 06:32 AM
djrazr's Avatar
A cv? I'll have to check to check it out because this was loud, like something was gonna fall off
Old Aug 3, 2009 | 06:34 AM
Lumpy's Avatar
They can make quite the racket and vibrate like mad when they decide to go.
Old Aug 3, 2009 | 08:19 AM
djrazr's Avatar
Do now do i replace the boot, or should i just replace the whole half shaft?
Old Aug 3, 2009 | 08:26 AM
desertcamper67's Avatar
Have someone rock the steering wheel back and forth (engine running) while you or someone with a little knowledge looks at your steering linkage,bushings,ball joints,steering gear or rack for independent movenent. Something might show up shifting under the load. This is how I used to find bad parts that others couldn't.
I don't suggest driving it until you are sure it is safe. Bad CV joint is fine to drive on unless it affects your steering.
Good luck.
okamikai
Apr 30, 2018 10:19 PM
lectric80
Aug 11, 2015 12:02 AM
gillesdetrail
Aug 3, 2015 04:43 PM
ripp96
Jul 25, 2015 02:32 PM
Hamonacracker
Jul 17, 2015 08:33 AM
