Passenger window stuck closed
Old Aug 12, 2009 | 12:18 AM
McQuaid's Avatar
Hi Guys
Ive spoken about this before but now its serious, yesterday afternoon, friend put passenger window down and then when we got out i said leave it down cuz it was very warm outside, then when i went to drive it the window wouldnt go up...nothing i can do will make the window go up?? last time this happened i played around with the window and something just "popped" back into position by the door lock lever but i cant get that to work this time, i stripped the panel off the door with no joy....can see anything....when i press the button for window to go down i can hear a little activation noise in the motor but nothing when it goes up.....
you reckon its a motor?? is there a way i can get this window up?? power to the motor some how??? as i was lucky last night as it didnt rain but i may not be so lucky tonight
Old Aug 12, 2009 | 12:39 AM
CRafferty's Avatar
First, make sure the switches you are using are good. They may not be getting any power. IDK much about electrical systems, but I do know they fail.
Second, check if the motor is any good? I've had 3 wear out on me.
Third, check if it is on the track correctly. It may have a problem there that is making the others seem like the process.
I think you should actually check if the windows are on track before the motor. I'm not sure though.
Old Aug 12, 2009 | 12:41 AM
McQuaid's Avatar
thanks for that, the window is on the track alright, so thats all ok but i dont know much abotu checking power to the motor or switches, i took the switches on both doors out and cleaned them off and there switiching correctly but dont know if there getting power
Old Aug 12, 2009 | 02:21 AM
McQuaid's Avatar
ok heres the latest, ive done some phase testing....the switch is getting power...the motor is getting power but no joy...i hooked up a battery to the motor itself and the motor put the window up no problem so motor is working fine...im stumped...now if i press down on the switch it will go down but if i press up it wont....ive tried the switches from the 2 back doors and they dont work, i have my back windows unhooked and have had since i bought it so i dont know if they ever worked...reckon it could be the switch at fault???
Old Aug 12, 2009 | 05:58 AM
93YotaGuy's Avatar
Sounds like a bad connection in the wire. Just take a hammer to it. That usually fixes things right up!
Old Aug 12, 2009 | 06:04 AM
McQuaid's Avatar
i feel like taking a sledge to it! trying to keep my self busy with my new pro comp ES2000 steering stabilizer and my 4 x ES9000's....there fitting on for me quite nice....havent started the shocks yet but anything to look out for???? stabilizer is fine so far
Old Aug 12, 2009 | 06:25 AM
BeMiceElf's Avatar
I used to have this problem on my 86. I finally figured out that inside the switch it starts to get some sort of build up and makes it not have a good connection. On mine if i took it apart and cleaned the switch it would work fine until it started to build up again. Hope this helps.
Hunter
Old Aug 12, 2009 | 06:29 AM
93YotaGuy's Avatar
I would start by taking the door panel off and really inspecting the setup. You could try using a motor from the drivers side to see if it is in fact the motor.
Maybe it just doesn't want to go up or you have a faulty wire/build up in there.
Take it apart and let us know how it works out...
westonian18
May 1, 2020 06:38 AM
okamikai
Apr 30, 2018 10:19 PM
coreyedwards7611
Jan 16, 2016 06:38 PM
britishdudes2dr
Jul 25, 2015 06:47 AM
CanRunner
Jul 20, 2015 01:29 PM
