22RE Idle Gremlins
Old Aug 7, 2009 | 12:22 PM
qdude79's Avatar
22RE Idle Gremlins
Might be a bit foreign, as many here have MT's, but my idle is all over the board.
I have an AT with AC, and can't find a happy medium. Set it between 750 and ~950 rpms in Park, won't idle well in gear. Turn on the AC, even worse, probably kill the motor. Set the idle to run well in gear and/or with AC on, idles between 1500 and 1700 in Park. Cold idle even higher. WTH???
Yeah, I know the damn AC idle up valve is supposed to help with AC on, but that's another Japanese mystery. Replaced everything, tested everything, nothing happens though all checks out fine.
Can you tell I'm frustrated???
Old Aug 7, 2009 | 12:29 PM
Lumpy's Avatar
Seafoam...give it a shot before you start replacing things even do it twice.
Old Aug 7, 2009 | 12:38 PM
qdude79's Avatar
Newer rebuild, ~10k miles. Professionally clean TB, intake plenum. Brand new injectors. Tank clean and fuel pump new. New fuel filter. All ignition parts new. Passes smog with flying colors.
Although I've used SeaFoam in the past, successfully, I don't know that it'd do much here. Thanks for the consideration, though. Am I off with my thinking about it?
Old Aug 7, 2009 | 12:49 PM
Lumpy's Avatar
Oooo Didn't realize your sig stuff was new stuff...That makes for a more interesting time. When did this start?
Hows about this? Check your timing, did you set it with the jumper in?
Old Aug 7, 2009 | 12:51 PM
qdude79's Avatar
Timing's at 6deg, jumpered, per Engnbldr's recommendation. Already tried advancing/retarding to see how it reacts. Nothing significant to report.
Old Aug 7, 2009 | 12:58 PM
plumo57's Avatar
I found a plug in one of my vaccum lines (in the metal section of the line between the manifold and valve cover). Once i got that unclogged, my truck went from idle all over to smooth idle.
Old Aug 7, 2009 | 01:05 PM
DupermanDave's Avatar
How did you find the clog and how did you clean it? Soak it in parts cleaner?
Old Aug 7, 2009 | 01:10 PM
qdude79's Avatar
I'm interested, too.
To clarify, though, my idles isn't necessarily up and down, just very different from Park to Drive with or without AC.
montanatruck
Feb 26, 2017 07:07 AM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
jake_v
Jul 22, 2015 03:17 PM
kcaudill
Jul 20, 2015 12:06 PM
kyletbert
Jul 17, 2015 11:39 AM
