1988 Toyota 22re EFI has starting problems please help
My 1988 toyota 22re will start great and run great up until it gets ran for a period of 30 min and when your turn the switch off and try to restart it just spends over. After the truck has cooled down a hour or two later it will start right back up again. I"ve replaced the coil & Ignitor and also the dist. and this has not fixed the problem any help would be appreciated.
Smartasses dont.
Alot of time people who dont search wont get alot of help.
Pretty sure issues like this have been covered before on this forum.
Hard to start warm?
Because you've been rude, all I should say is I'd suspect something's wrong.
Since you've edited replies and apologized to at least one member:
maybe intake duct leak, vacuum leaks, faulty engine temp sensor, leaking fuel injector(s), low (or possibly high) fuel pressure, incorrect ignition timing, wiring issue or cam timing or valve adjustments... maybe even a whole series of tune-ups done that mask a faulty idle / air control valve.
Hope I didn't give you too many things to consider.
And troubleshooting info for all those is available through Yotatech's search function and through various Factory Service Manuals which also can be found with the search function.
6th Gear
19
12-10-2019 07:31 AM
Peteyg39@hotmail.com
06-26-2015 08:15 AM
