4runner parking brake question....
Old Aug 5, 2009 | 12:22 AM
KODE's Avatar
I just did a 5" rear leaf swap on my 90 4runner and my parking brake cables are just about 2" too short to make it back into the drums. is there any other way to run the 4runner parking brakes beside buying the t-case brake kit??? any one have experience in solving this problem?? any help is greatly appreciated!
Old Aug 5, 2009 | 12:43 AM
vital22re's Avatar
totally a bro
could you get the cables from a truck to work?
Old Aug 5, 2009 | 12:50 AM
wyoming9's Avatar
Red face
You might be able to make a piece of cable to lengthen it by putting in a piece where the adjuster is .
without seeing one of that year I can`t really say just how it would need to be done.
I am sure something can be worked out.
Old Aug 5, 2009 | 06:08 PM
KODE's Avatar
i cant use one from a truck because the 4runner has 1 parking brake cable on each side of the axle. trucks only have 1 cable that goes into the drum, then has another cable running across the axle to the other side. if not, ill just have to run the transfer case brake.
Old Aug 5, 2009 | 06:20 PM
myyota's Avatar
Does the parking brake cable run along the frame next to the gas tank ?, if it does then cut the last clamp thats holding the cable to the frame and that should give you the extra length that you need. I did this on my 4Runner and it worked out good.
Old Aug 5, 2009 | 09:14 PM
abecedarian's Avatar
For the record, a transfer case / trans brake is illegal to use as a parking brake in the USA. They are not illegal to have but are not legal for said use on road.
Got a pic of your setup?
Old Aug 6, 2009 | 01:05 AM
KODE's Avatar
ill try removing the bracket and see if it reaches. ill try to take some pics.
Old Apr 7, 2011 | 02:17 PM
Dras16's Avatar
I know this is an old thread but did you ever figure out a way to make your cable work?
Charecter1
Nov 6, 2023 10:08 AM
ashersullivan88yota
Jan 18, 2022 05:37 PM
Jun 1, 2021 01:51 PM
87turboPA
Jul 12, 2015 07:49 AM
Jnkml
Jul 6, 2015 01:20 PM
