BIG idle differences between Park & Drive
Old Aug 12, 2009 | 09:32 AM
qdude79's Avatar
Obviously an auto, 22RE.
I set timing and adjusted idle for driving, at stoplights I'm between 800 and 900 rpm. Park, I'm at about 1500! Cold starts, above 2000rpms!
Now, if I adjust for Park and cold starts to be more "normal," stoplight idle is non-existant (it dies). Turning on AC, forget it.
Why the major difference between the two???
Old Sep 9, 2009 | 06:55 PM
abadgti's Avatar
Bump because im having the same issue. Idle in park when cold is 2000 and 1500 when warm. Idles at 900 when in drive. Can anyone help?
Old Sep 9, 2009 | 07:00 PM
abecedarian's Avatar
Without knowing much more, I'd say vacuum leak(s)... maybe ignition advance too high.
My 91 auto idles in P or N at about 1100 cold (90F ambient) and comes down to 800 (160F+ in the engine)... and to about 700 in D, R, 2, or L.
Old Sep 9, 2009 | 07:07 PM
OutlawMike's Avatar
I had a similar issue recently. I could not get the idle low enough with the pins jumped in the test connector. Even with the idle screw all the way in, I could not get it to drop to spec. In park or neutral, idle was 1200-1500 RPM. This was on a 3VZE, not sure if the 22RE has the same design.
It ended up being the coolant temp controlled solenoid in the bottom of the throttle body. The passageways were clogged in the throttle body, no flow was getting through. I flushed it out and the problem went away. That solenoid is designed to expand and push a piston into an opening. At startup it is a designed in vacuum leak. At temp it is supposed to close down.
You might look there, if you cannot find any vacuum leaks elsewhere.
Good luck
Old Sep 9, 2009 | 07:10 PM
qdude79's Avatar
Pics??
Old Sep 9, 2009 | 07:26 PM
OutlawMike's Avatar
Originally Posted by qdude79
Pics??
Here is the thread on my fix:
https://www.yotatech.com/forums/f116...le-fix-188519/
Old Sep 9, 2009 | 08:29 PM
abadgti's Avatar
Thanks for the response. I will try what you suggested and see if that helps.
Jnkml
Jul 6, 2015 01:20 PM
B. Graves
Jul 3, 2015 04:10 AM
TNRunner88
Jul 1, 2015 08:00 PM
DanStew
Jun 29, 2015 10:46 AM
David_Vestfal
Jun 20, 2002 08:30 PM
