Can u help out identify this lines
Old Aug 9, 2009 | 10:51 AM
Raymond_Q's Avatar
I am currently removing vacuum lines, I cant seem to figure what these lines are(next to the pen). I believe they where hooked up to the carcoal canister, and they also lead to the gas tank. I replace oem carb and intake with a weber/offenhauser setup. Should i just block them
off?
Old Aug 9, 2009 | 11:13 AM
Travisfab's Avatar
Just trace them back to their source.
Old Aug 9, 2009 | 11:33 AM
Tragic Drive's Avatar
Yeah it goes to your vapor canister. That's the Vapor line from the gas tank.
Old Aug 9, 2009 | 11:49 AM
myyota's Avatar
You should leave the charcoal canister in place, otherwise you have fumes from your gas tank venting to the air and that could be dangerous if a spark or some other heat source should ignite the vapors.
Old Aug 9, 2009 | 12:13 PM
yoterr's Avatar
x2, you cant block em off or ull have excess pressure buildup in the tank... lol
Old Aug 9, 2009 | 04:54 PM
Raymond_Q's Avatar
sweet thanks guys
cr@ves4wheelin
3.4 Swaps
Aug 17, 2015 07:47 AM
DadsTruck
Aug 1, 2015 09:14 PM
pyramid
Jul 30, 2015 10:05 AM
rushw
Jul 18, 2015 01:46 PM
Fundy Rider
Jul 16, 2015 01:35 AM
