power window's and locks
Old Aug 10, 2009 | 04:03 PM
ltgvolsrock1's Avatar
ok i have a 92 4x4 truck that i would like to put power windows and locks in.. has any one done this before? could you just take the door off a 4 runner and put it on a truck of the same year??? thanks
Old Aug 10, 2009 | 04:16 PM
foot0069's Avatar
Nope doors are different size. The wiring will be a PITA if you want to stay stock. The easiest way to wire will be add a fuse box and pull all your hots there. The stock window's and locks are ecu controlled.
Jim
Oh forgot, cause I've never seen one in person, but have seen on here that the 2 door 4 runner doors are the same.
Old Aug 10, 2009 | 04:31 PM
Marc's Avatar
I put power locks into my 91 4runner.
They were aftermarket. Took a couple hours per door.
Old Aug 10, 2009 | 04:33 PM
eighty5yota's Avatar
any key details? im interested in doing power locks on my 85
Old Aug 30, 2009 | 06:20 PM
sounds good thanks for the info. does any one have a pic of there truck they converted? thanks
Old Aug 30, 2009 | 09:12 PM
xXbrutalXcoreXx's Avatar
I went with with Commando alarm mainly for the price factor. This has everything you need to convert your doors to power locks as well as gives you keyless entry and an alarm. I have had this kit on my truck for the better part of a year and have not had one single complaint. I am not going to lie, it was quite a PITA to install and took a whole entire Saturday. But the results are well worth it.
Link: http://www.commandocaralarms.com/ite...ProductID=1463
As far as power windows go... Personally i think it would've been pretty difficult to install any kind of window actuator in such the small space behind the door panel. That doesn't mean that it couldnt be done though. Here is commando's link for power window stuff: http://www.commandocaralarms.com/power-window-kit.asp
Hope that helps!
Old Aug 30, 2009 | 10:22 PM
Jay351's Avatar
I pulled the electric stuff out of the doors I bought (got all the wiring, and the big relay that it uses) and it all bolts up the same as the manual stuff.
all you would have to do is install the componants (new door panels too!), drill holes for wiring into the cab, and then wire the 2-4 clips per door.
Old Aug 31, 2009 | 10:36 AM
bhanu128's Avatar
i have a 92 ssrx , and it has power shutters but they are not worth the trouble if u ask me...req lots of maint..
Old Nov 5, 2010 | 12:10 PM
dannyreckless's Avatar
Hope that helps!
DId you also have to purchase http://www.commandocaralarms.com/ite...ProductID=1525 ?
I am considering doing this as well.
Old Nov 7, 2010 | 04:31 PM
yeehaw1's Avatar
Will 2 door 4runner electric doors fit on an 87 Toyota pickup ext cab? If so is the wiring harness on the pickup wired for the electric windows/locks?
Thanks, and sorry to hijack, but thought there was no since in making two threads for similar ?s.
Old Nov 8, 2010 | 05:18 AM
dntsdad's Avatar
I swapped mine out when I was doing my 3.4 swap.
Info is here
Jun 1, 2021 01:51 PM
westonian18
May 1, 2020 06:38 AM
coreyedwards7611
Jan 16, 2016 06:38 PM
RustBucket
Jul 24, 2015 04:46 AM
Johntom240
7
Jul 13, 2015 12:18 AM
