PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 [61] 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. High HC on emissions after tune-up 87 22RE 4runner
  2. Anyone have a All Pro Expedition Series Pack Rack?
  3. 1989 4Runner 22RE no power - can't pass smog
  4. W-56B vs W-56C
  5. Check Engine Light (Code 71 - EGR) question
  6. rear suspension and weight in bed. cross country move NEED ADVICE ASAP
  7. 93 Toyota Pickup 3.0L v6 Engine rebuld Help
  8. 2nd Gen 4runner vent window swap/conversion: a How-To Guide
  9. Bizarre Transmission Noise?
  10. 88 4Runner 3vze tapping
  11. 1991 toyota pickup puzzled by my power steering hose
  12. Help with rear diff (ring and pinion)
  13. Brake Light on Instrument Cluster Flickers
  14. Somethings switched (pun intended)....
  15. 22RTE Headgasket and ARP questions
  16. 86 toyota 4x4 sr5 turbo truck bad turbo
  17. Back window will go down but not up
  18. what i have learned (88 4runner 22re)
  19. New to carbed engines. Help appreciated
  20. Brake problems
  21. Ac vaccuum question
  22. Anyone running 17x9's rims
  23. Idle is rough after AC is turned off
  24. 94 4Runner - Idle and Acceleration Hesitation
  25. Heater core extension pipe??
  26. part number for joining upper and lower intake pendlum gasket
  27. 1993 4runner 3.0 problem
  28. 84-89 4runner sr5
  29. Running Rich, Help Me Read These Values
  30. No start condition (VAFM or COR)...I'm at a total loss for what the symptoms mean.
  31. Battery Drain
  32. Time for a new ignition switch?
  33. 98 hilux ute RN85, How to fold rear bench seat??
  34. 4 hole 3.0 injector install, kinda broke something....
  35. New to site with new purchase 94 truck
  36. marlin w56b short throw vs just replacing bushings
  37. 1993 3.0 v6 4runner acceleration
  38. Speedo cable keeps breaking
  39. New guy: How do I tell r12 or 134a?
  40. Oil Pressure
  41. Frames
  42. Advice on electrical wiring for high engine temps
  43. custom 4runner top build aka (the crew cab build))
  44. LC Engineering
  45. 1994 22RE 275,000 Miles NO POWER
  46. 94 2 Dr pickup plastic shrouds?
  47. Metal clamshell coupler leaking coolant
  48. '95 DLX Front Brakes
  49. 3zve Power Steering Pump replacement questions
  50. idling issue
  51. SS Cat Back for '95 DLX
  52. I need help with front leaf hanger.
  53. 87 4runner have fuel and spark but will not run...
  54. What flamethrower injectors are better?
  55. rebuilt started finally but sounds and runs horrible
  56. Testing for Vacuum Leak
  57. Factory brush guard
  58. What gear ratio to go with for towing?
  59. Ball joint spacer install on 95 pickup help...
  60. 1991 Toyota Pickup Air Conditioning issues
  61. Aftermarket gears in factory 4.88 3rd
  62. new fuel pump making noise 22r
  63. 94 4runner 3.0 NO START
  64. identify the part name
  65. will a v6 auto trans work with a 22re?
  66. my 22re is going bananas. Overheating, throwing codes, not idling.
  67. 1989 Toyota 4x4 over fueling
  68. Ring gap question please help!
  69. Ball joint spacers
  70. Short some where
  71. 91 22re low idle 300-400 rpm stumbles
  72. 90 4Runner post engine rebuild questions
  73. Rear Sway Bar + Chevy 63's
  74. Backrack For Tacoma on 94 Pickup?
  75. '88 22RE Vacuum Line Question
  76. 1987 pickup wont idle
  77. blown head gasket help
  78. Weber
  79. cold blooded
  80. TPS questions
  81. relays going crazy now
  82. 94 Pickup 3.0 3VZE Fuel Injector Question
  83. full custom idler arm build tread w/pics and info
  84. Air injection piping
  85. 87 Turbo EFI will not stay running! HELP
  86. First truck questions
  87. power steering
  88. G58 transmission - OK to use 80w90?
  89. Process for removing manual steering box
  90. I press the gas...truck doesn't move (Pickup 3.0 auto)
  91. Truck had a poor 22re to 22r swap need help
  92. Rebuilding entire front end
  93. 1990 4runner 3.0L transfer case swap????? NEED HELP!!!!!
  94. How is your first gen 4runners exhaust pipework? Pics?
  95. So. Head gasket rebuild.
  96. Can-Bak soft top help
  97. 3vze egr/pair reed valve delete
  98. Will an 88 4Runner fuel tank fit an 89 PickUP?
  99. New power antenna does not go up
  100. Vibration is driving me crazy
  101. 95 4 Runner 3vz-e fan pulley issues
  102. Play in steering.
  103. What Bore Size Master Cylinder W/ Rear Wheel ABS?
  104. Carb ?
  105. AC cut off relay temp switch
  106. How do you wire a 4pin for brakes
  107. Stumbling/misfiring only on hills and extended drives..
  108. 91 3VZE timing woes
  109. 92 22re w/auto lacks power going up hill
  110. 94 Pickup wipers not working
  111. 88 4Runner automatic transmission
  112. Lower Rear Shock Mounts '87 p/u
  113. 91 runner heavy clutch
  114. Help with DIY roof rack - how to attach to roof
  115. Rear diff. Noise
  116. how much will it lift my runner?
  117. 22re distributor disassembly?
  118. Cruise only working with lights off
  119. Bizarre combination of issues after my accident
  120. Where can I buy heavy duty leaf springs for my '93 V6 pickup?
  121. Upper Control Arm close to sidewall?
  122. 1990 pickup
  123. Still blowing efi fuse
  124. Need Help looking at Yote
  125. need to know if it will work
  126. Need advice on possible short.
  127. Going to do a motor swap. Wanting to know what to look out for
  128. 3.4 sourced. Lemon?
  129. Help mpg
  130. Heater AC Face Plate Bezel Part #
  131. Starting Issues
  132. 95 pickup parking brake cable replacement?
  133. Post Your Blazeland Long Arm Set-Ups
  134. 1995 4Runner light bar mount
  135. Brake Problem
  136. 5" trail gear leaf spring mount relocation
  137. Mounting TPS
  138. Cabin / AC Filter on '86 Truck
  139. Speedo is off a whopping 32%!!!!
  140. tapping when cold gets worse when warm
  141. Aux air valve 22re
  142. Swapped Engine, Won't Start, No Fuel, No Power to Injectors
  143. No power to fuel pump fuse keeps blowing
  144. A/C issues - 1990 4Runner 3.0
  145. timing chain question
  146. 91 4runner and Bulldog Keyless entry system
  147. where to get a speedometer gear ??!
  148. Please help me diagnose this 22RE miss
  149. 91 efi swap into a 87 4wd need help !
  150. New member. Clean 86 extra cab.
  151. 94' 4 Runner rear spoiler and black powder coated tailight covers/guards.
  152. New member and first time Toyota owner.
  153. Going nuts and need help...22re TPS?
  154. sourcing a w56 rebuild kit
  155. 89 4Rnner 22RE cooling issues following Radiator replacement
  156. speedometer sensor?
  157. a/c relay
  158. Side view mirror swap
  159. What is this on my radiator?
  160. 94 4Runner Skid Plate Removal ?
  161. New here, have an issue with topend..Or at least I think.
  162. Trim emblem next to door
  163. 89 toyota pickup speedometer broke in 2 pieces
  164. And let the fun begin.. VCG&TB/WP replacement
  165. No spark
  166. HELP!! 1989 4runner Clutch Problem
  167. PS pump issue- found no vacuum switch attached
  168. wont start, I just here clicking when I turn the key
  169. 3vze no start resolved
  170. Help with 3.0 stumble and rough idle.
  171. Cut Engine Wiring Harness...Is this Common?
  172. rear main seal leak?
  173. Electrical issue
  174. I'm going to need some help.
  175. Front torsion beam upgrades?
  176. 3vz Spark Plugs Swap
  177. 3vze no start resolved
  178. Sunroof Rear Drain Location??
  179. 2nd gen pickup f150 spring swap questions
  180. V belts
  181. wont rev past 2000 rpm
  182. Mystery Wire
  183. Supreme Suspensions ?
  184. 93 t100 v6 maf sensor 2 screw mistake
  185. 1994 Toyota pickup rear bumper with integrated receiver options?
  186. Will newer TRD wheels fit on my '87 Pickup 4x4
  187. Pulling Out a 3VZE: A Couple Questions
  188. 3VZ-E running HOT
  189. Nasty Transfer case
  190. Ticking after tune up?????
  191. 1993 pick up antenna replacement
  192. 1993 3vze slow coolant leak before and after HG replacement...
  193. Intermittent Transfer Case Noise and Engagement?
  194. Zuk mod
  195. 1990 Toyota pickup
  196. Guerrilla Maintenance! Pics to
  197. 1988 22re won't go over 20 mph!
  198. No acceleration power
  199. batt/brake light woes
  200. Failed Ca. Smog possible timing issue
  201. Flamethrower's Injectors (Review and Hardwiring New Connectors Tutorial WIP)
  202. Clutch trouble
  203. Yet another TPS thread
  204. 3VZ-E timing belt tips?
  205. 22RE harder to start in hot weather..
  206. Pulling Out a 3VZE: A/C Question
  207. Throttle Body
  208. 22R took a poo on me
  209. 3VZE Timing Advice - Another Idiot (Me)
  210. Tail Light options
  211. 92 4runner rear wiper arm issue
  212. 22re running great except.....
  213. When to Replace Timing Chain...22RE?
  214. Standard Cluster into Auto Chassis
  215. rear leaf spring questions
  216. door pins
  217. 4runner brush guard compatability
  218. Starting problem
  219. wont turn over
  220. Rain leaking under glovebox while driving
  221. '92 Standard Pickup won't turn over after valve adjustment.
  222. Help remove rusted drums 87 4R
  223. 5spd Swap reverse light wiring
  224. 86 4runner
  225. Draglink Question
  226. Is my Fuel pump dead?
  227. Excessive Heat from Gear Box / Transfer Case
  228. No power under load barely get up to 60km/hr
  229. Starter
  230. LSPV: to bleed or not to bleed?
  231. Front and rear driveshaft yokes interchangeable?
  232. Clarification Needed: Fuel Injector "Holders"/"Grommets"
  233. Problem with Bosch 4 hole injectors
  234. Any Yota'techies in las vegas to help with fresh rebuild first startup fine tunning..
  235. 94 22re dragging start
  236. Alternator and brake light come on intermittently
  237. 88 22RE Throttle body questions.
  238. Is a used windshield worth using or selling?
  239. 1990 sr5 d.s. support bearing quandry
  240. My 4runner smells like gas?
  241. Oil and alternator lights come on together while driving.
  242. Do I need a new valve cover? 3vze
  243. Clutch start cancel can't start with clutch
  244. Manual Hub ball replacement
  245. Rear Leaf Hanger Measurements for 2nd Gen 4Runner... because I've seen so many
  246. 2 inch lift
  247. Leaking Rear Main Seal - Advice?
  248. voltage light
  249. Somebody please help me before I unload my S&W 45 semiautomatic into my 95 Toyota 4 r
  250. Cant find a fuel sending unit/bracket!
