Short some where
Old Jun 30, 2014 | 10:31 AM
92-4runner4x4's Avatar
Short some where
Hey guys! I've got a 1992 4x4 4 runner 3.0 my starter went out on me and I put a new one in I took it to a shop and they swapped it out with a smaller one not the same size? Ever since I put that starter in I tryed to jump my battery since it was dead and the jumper cable arcled and it blew my 80 amp alternator fuse my eti fuse my lamp fuse idk what's going on could anyone maybe give me some advice of what could be going on?
Old Jun 30, 2014 | 10:47 AM
JasonYota's Avatar
Did you cross the jumper cable wires? Did you replace the fuse that blew? What is the truck doing?no power anywhere, not starting?
Old Jun 30, 2014 | 11:00 AM
there's no power to the truck at all unless I put a screw driver in the 80 amp fuse! Then there's power but then the truck still won't turn over it's just like a click noise not as the battery is dead. Idk what to do
Old Jun 30, 2014 | 11:08 AM
JasonYota's Avatar
No telling what's fried if you stuck a screwdriver in the fuse slot. Defiantly a no no.
Old Jun 30, 2014 | 11:11 AM
JasonYota's Avatar
There is no power even when you replaced fuse with a good one?
Double check your starter wiring make sure it's tight, and no nicks in the insulation that could ground out.
Old Jun 30, 2014 | 04:08 PM
RAD4Runner's Avatar
...it blew my 80 amp alternator fuse my eti fuse my lamp fuse...
Do you mean to say it also blew your EFI fuse and TAILlamp fuse?
If, and only IF, you wired the starter correctly, AND IF, and only IF, you or shop did NOT mess with anything else, I could not think of anything on that starter that would draw 80 amperes enough to blow your Fusible Link.
IF the shop wrongly connected the supply to your starter solenoid to the supply bolt of your starter motor , yes cranking current running through your starter motor could easily blow the fuse.
Wanna post a diagram or pictures of how exactly shop wired to your starter? Otherwise, other members who may be thousands of miles away from you could not visualize what's going on.
I8URSVT
Mar 2, 2021 06:23 AM
Alexdosdall
Dec 10, 2017 05:48 PM
JPV
Sep 28, 2015 03:15 PM
gentry
Sep 28, 2015 06:16 AM
