TPS questions
Old Jun 28, 2014 | 07:46 PM
Relyks's Avatar
TPS questions
if my TPS is not set correctly could it cause it to throw a code for the MAF and itself, also could it cause the truck to back fire at high rpm if not set correctly or not working.
code
24: intake air temp open or short in signal
31: Manifold and or airflow meter sensor signal
41: TPS Sensor signal open or short
Old Jun 29, 2014 | 07:34 AM
Relyks's Avatar
Bumppppp
Old Jun 29, 2014 | 08:04 AM
Rerunn's Avatar
I'd start ohming out that afm
Old Jun 29, 2014 | 10:37 AM
jbtvt's Avatar
Probably not. Post your AFM and TPS resistance check results.
Old Jun 29, 2014 | 10:50 AM
Relyks's Avatar
afm tps vacuum
Ill post my readings in 30 mins, is there a chart i can use as refrence. Also is there a 91 full vacuum diagram my vsv is acting strange. Also i read you put in the dizzy at 5* on the crank with the rotor at 12* on the small dizzy gear can anyone confirm this, and is there actual marks on the dizzy that indicate 12* or just rotor facing 12 oclock.
Old Jun 29, 2014 | 01:23 PM
scope103's Avatar
The answers to all questions are found in the Good Book:
http://personal.utulsa.edu/~nathan-b...92volumeai.pdf
http://personal.utulsa.edu/~nathan-b...93throttle.pdf
http://personal.utulsa.edu/~nathan-b...13distribu.pdf
Old Jun 29, 2014 | 07:05 PM
Relyks's Avatar
22re
Sorry, this is all 22R-E out of a 1991 2wd pickup I never really clarified.
Gone Fission
Jan 12, 2023 10:34 AM
Blamalam
Mar 12, 2022 07:34 AM
Sidherish
Aug 3, 2015 07:17 PM
Gone Fission
Jul 31, 2015 03:58 AM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
