Oil Pressure
Old Jul 5, 2014 | 09:04 PM
NickS022's Avatar
Oil Pressure
I went wheeling today and on the return trip I noticed that I had almost no oil pressure ( per dash gauge) but it ran fine. The trip was really bumpy with some hills and the truck has been on level surfaces like more than 90 percent of the time cuz its my DD.! My question is should I be concerned that the gauge in dash says low oil pressure if it runs fine and I have no leeks.?
P.S.
I hate bike woops
Old Jul 6, 2014 | 12:25 AM
wyoming9's Avatar
Red face
Yes one should always be concerned !!! When these things happen.
Yes it will run fine right up to it starts knocking .
Might be time to install a manual gauge or at least use one to check your oil pressure.
Your sending unit might be getting old and tired.
Old Jul 6, 2014 | 06:18 AM
scope103's Avatar
I'd start by checking that the connector to the sender is still attached. Of course, with a "bumpy" ride you could break the wiring anywhere. (For that matter, you could also break the hose on a manual gauge just as easily.)
As wyoming9 says, oil pressure is a "good thing." Never ignore a warning about it.
Old Jul 6, 2014 | 04:28 PM
NickS022's Avatar
started up fine this morning and ran like a champ like Toyota does and everything returned to normal, but just in case where can I find the oil pressure sending unit on a 3vzE
Old Jul 6, 2014 | 04:37 PM
JasonYota's Avatar
Right beside the oil filter is the sending unit.
Old Jul 13, 2014 | 07:21 AM
KingsShadow's Avatar
Might be time to install manual gauge or at least use one to check your oil pressure.
Replaced many broken wires on these sending units. So for a "stupid" question. If it showed no oil pressure why not just pull over and double check the oil dipstick just in case?
bigjstang
Jun 2, 2025 03:56 PM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
calderp
Jul 27, 2015 09:58 AM
Odin
Jul 15, 2015 09:28 PM
88yodabasket
Jul 13, 2015 01:32 PM
