Oil Pressure
Oil Pressure
I went wheeling today and on the return trip I noticed that I had almost no oil pressure ( per dash gauge) but it ran fine. The trip was really bumpy with some hills and the truck has been on level surfaces like more than 90 percent of the time cuz its my DD.! My question is should I be concerned that the gauge in dash says low oil pressure if it runs fine and I have no leeks.?
P.S.
I hate bike woops
P.S.
I hate bike woops
Yes one should always be concerned !!! When these things happen.Yes it will run fine right up to it starts knocking .
Might be time to install a manual gauge or at least use one to check your oil pressure.
Your sending unit might be getting old and tired.
I'd start by checking that the connector to the sender is still attached. Of course, with a "bumpy" ride you could break the wiring anywhere. (For that matter, you could also break the hose on a manual gauge just as easily.)
As wyoming9 says, oil pressure is a "good thing." Never ignore a warning about it.
Odin
Jul 15, 2015 09:28 PM
88yodabasket
Jul 13, 2015 01:32 PM
