Problem with Bosch 4 hole injectors
Old Jun 9, 2014 | 08:24 PM
mr.c68's Avatar
Installed a set of yellow Bosch 4 hole injectors (the 2% more fuel ones) in my 89 3VZE 4runner & now I can't get her started. The cold start injector is doing its job as it tries to start for about 1 second (wont fire at all with the cold start unplugged). Any suggestions before I tear it apart & send these back? I already know Bosch Bad / Denso Good but at $120 for 6 I was really hoping for the best.
Old Jun 9, 2014 | 11:11 PM
Terrys87's Avatar
I would replace them with Flamethrowers Injectors and he is a vendor on here. To your original problem of it not firing. Will it run with a shot of starting fluid into the plenum? Are you sure you are getting fire to your injectors or fuel to the injectors? Toyota likes their ground wires and if you didn't get it installed, that could be holding you up. It sounds like you may have missed a connection somewhere to me or something similar. What was the reason you changed your injectors to begin with?
Old Jun 10, 2014 | 07:44 AM
mr.c68's Avatar
I believe these are flamethrowers from ebay. Everything is connected, grounds were all done previously, and I changed them because I had one leaking & all old. If I have time today I will try to get to the bottom of this.
Old Jun 10, 2014 | 09:33 AM
Thehollywood811's Avatar
Make sure your maf is plugged in!! Done that way to many times, it's easy to overlook..
Old Jun 10, 2014 | 10:09 AM
mr.c68's Avatar
Everything is plugged in.
Old Jun 12, 2014 | 09:43 PM
mr.c68's Avatar
I forgot to attach the ground from the injector harness.
Old Jun 18, 2014 | 12:37 PM
Flame Thrower's Avatar
FormerVendor
any updates?
Old Jun 18, 2014 | 01:37 PM
mr.c68's Avatar
Gremlins! I thought I forgot the injector harness ground but it was right where it was supposed to be. I pulled the EFI fuse, re-installed it and "it lives"! Runs better than ever. I have no idea what caused the problem but it is gone.
Old Jun 18, 2014 | 02:03 PM
FormerVendor
OK. glad to hear it. let me know if there is anything else i can do for you.
FT
Old Jun 18, 2014 | 04:18 PM
mr.c68's Avatar
Thank you Sir.
Old Jun 19, 2014 | 09:23 AM
Gamefreakgc's Avatar
The new injectors have a different flow rate and pattern, pulling the EFI fuse is standard when installing any fuel modifications or replacements. Chances are it was putting on too much or too little fuel and by setting it back to "stock" settings it now flows the correct amount for combustion. Fuel won't burn without the correct oxygen ratio.
Old Jun 19, 2014 | 09:40 AM
mr.c68's Avatar
I should have mentioned that I did reset the ECU before initial startup.
Old Jun 19, 2014 | 09:44 AM
Well, that is interesting! Glad it works though and hopefully it never flares up again.
Old Jun 19, 2014 | 10:09 AM
How is the power curve on those things compared to stock? Really looking into getting a set
Old Jun 19, 2014 | 10:25 AM
It seems as though each rig reacts a bit differently since they own have their own flow rates and the state of the injectors you are replacing.
For me, increased low-end torque and smoothed out the power curve a bit, not much top end gain but a little. My shifts points can be lower now and not having to rev it up to 3000+ just to keep up with California traffic.
Plus if you polish up your old set, I was able to sell mine for about $75 on Ebay!
Old Jun 19, 2014 | 03:49 PM
http://m.ebay.com/itm/261228448791 Those the ones you got by chance?
Old Jun 19, 2014 | 03:55 PM
FormerVendor
no. the new ones i am selling are http://www.ebay.com/itm/271507061431
Old Jun 19, 2014 | 04:36 PM
Krazy Ken's Avatar
Your listing shows 1989 as the starting year. Will these not fit a 1988 3zve?
Old Jun 19, 2014 | 06:05 PM
MudHippy's Avatar
Fit? Yes.
Work? No.
The only ones he sells that will fit and work in an 88 3VZ-E are the http://www.ebay.com/itm/Toyota-4Runner-Pickup-Celica-84-87-22RE-2-4L-upgrade-fuel-injectors-/261238752845?pt=Motors_Car_Truck_Parts_Accessories&hash=item3cd30b064d with EV1-male to denso-female wiring harness adapters.
Originally Posted by Flame Thrower
1988 was a stand-alone year on 22re/3vze injectors. they have the later denso-style wiring plugs and the early low-ohm windings. you can use the earlier 84-87 22re injectors but you have to use wiring harness adaptors to go from EV1-male to denso-female.
Old Jun 19, 2014 | 06:10 PM
FormerVendor
for the 88, it's as the gentleman said, a different deal. call us tomorrow at 888-621-0794 and we can make arrangements.
FT
