95 4 Runner 3vz-e fan pulley issues
Old Jun 26, 2014 | 07:10 AM
gotweasel6's Avatar
So out of the blue my 4 runner decided it wanted to have the 2 pulleys that operate the fan to just sieze up and burn through one of my belts. Not sure what is going on, any advice would be helpful. Truck still starts up, fresh oil change...frozen pulleys :/
Old Jun 26, 2014 | 09:04 AM
scope103's Avatar
The pulleys don't operate the fan, the belts do. So presumably one (more?) of the pulleys on one (two?) of the belts failed. This isn't rocket surgery; since the belt is gone, you can put your hand on the pulley(s) and see if it will turn.
My guess is the idle pulley; it sits low and is subject to crud. http://www.toyotapartsoverstock.com/...844035030.html
Old Jun 26, 2014 | 09:18 AM
gotweasel6's Avatar
Neither of the two pulleys directly behind the fan move
Old Jun 26, 2014 | 09:28 AM
JasonYota's Avatar
Sounds like the water pump seized up. Time to start taking things apart
Old Jun 26, 2014 | 01:40 PM
scope103's Avatar
This one? http://personal.utulsa.edu/~nathan-b...50waterpum.pdf (for the 22re)
Old Jun 26, 2014 | 01:44 PM
gotweasel6's Avatar
So if the water pump is bad, will that cause the fan to not spin? I just pulled off the fan, heat sink, and pulleys.
Old Jun 26, 2014 | 01:48 PM
JasonYota's Avatar
What's not spinning? Just the fan? Fan pulleys and fan? Since you have it off does the water pump spin?
Old Jun 26, 2014 | 01:52 PM
gotweasel6's Avatar
When the truck was running the fan was not spinning. The belts just started squealing and smoking until one snapped. Before I pulled the fan off it spun by hand with a lot of resistance (not sure if that is normal)
Old Jun 26, 2014 | 02:01 PM
scope103's Avatar
Not normal; when the fan is "warm" it's only turning the water pump, which should turn easily. (When cold, the fan is disconnected and spins even easier.)
Again, assuming you have a 22re (the 3VZE is completely different), it sound like a jammed water pump.
Old Jun 26, 2014 | 02:06 PM
gotweasel6's Avatar
3VZE is what I've got, but I'll take the issue of the water pump and replace it.
Old Jun 26, 2014 | 03:48 PM
rworegon's Avatar
It sounds like the bearing in the fan bracket (false water pump) that the fan mounts on may have seized?
http://personal.utulsa.edu/~nathan-b...67timingbe.pdf
Old Jun 26, 2014 | 04:08 PM
scope103's Avatar
Ya see, the two engines are completely different. As rworegon points out, your water pump isn't even connected to the belts that failed. Your problem (from your description) is the fan bracket.
You can get it from the dealer, cheaper from an online dealer. http://www.toyotapartsoverstock.com/...630765040.html
But for me, I used an aftermarket part. Something like: http://www.fcpimport.com/products/to...00-16307-65040
Good luck!
Old Jun 26, 2014 | 04:33 PM
rworegon's Avatar
Or, even cheaper at RockAuto for the AISIN FBT-007 which is the same part as scope103 shows above, but without the Toyota box.
OP, post up a pic or two?
Old Jun 27, 2014 | 11:43 AM
StayFoolish22's Avatar
Just dealt with this. Don't get the cheap one from Napa. It broke again 3 days later. They sell a better quality one for 90 bucks more. Made by the right china company. Forgot the name. I paid 400 "I think out the door. Might as well do the timing belt and water pump while you are in there. Took me a few days of easy work with no prior experience. I could do it again in a few hours tops now though.
voiddweller
19
May 2, 2016 09:10 PM
noahstancik
Jul 10, 2015 11:18 AM
ian1386
Jul 1, 2015 11:23 AM
marcusSRG
Jun 27, 2015 07:13 AM
sharrack
Jun 26, 2015 09:33 AM
