blown head gasket help
Old Jun 29, 2014 | 01:34 PM
jonathan7's Avatar
I need some help i got a 92 pickup 22re and i had oil in the coolant so i changed the head gasket and took the head to a machine shop got it shaved. Then about a month later it over heater jus barely about normal i thought was weird so i checked the coolant had oil again. So i took the whole engine out got a new head, decked the block, new piston rings while i was in there, bearings, every new gasket, put it all together. A week later it wasnt over heating but i went to check the coolant and had oil again. Anybody had the same problem...help
Old Jun 29, 2014 | 01:42 PM
rworegon's Avatar
Welcome to YT!
Take a look at these threads. They may spur an idea:
https://www.yotatech.com/forums/f116...-bolts-219076/
https://www.yotatech.com/forums/f115.../#post52206353
Old Jul 13, 2014 | 07:40 AM
KingsShadow's Avatar
Have you had the front timing cover checked? 22re engine is notorious for the chain grinding through the aluminum timing housing, into the coolant passage.
kgcwb44
Jan 29, 2023 10:02 AM
the1998sr5
15
Jul 14, 2020 08:35 PM
4x4-runner
Dec 27, 2016 01:58 PM
Coreyr384
Jul 10, 2015 11:13 AM
87blyota
Jul 10, 2015 04:31 AM
