wont turn over
Old Jun 11, 2014 | 11:27 AM
JackiesToy's Avatar
wont turn over
yesterday I went to crank my truck, and it wouldn't start, so I tried to have it jumped off thinking it was the battery no luck, so thinking it was the alternator had it taken off, I took the battery and the alternator had them both tested, both testes good, so now we have replaced the starter, still no luck, the only sound coming from it is clicking, we think it's an ailment problem with the started is there anyway to test that or anyway to fix it?
Old Jun 11, 2014 | 12:06 PM
RAD4Runner's Avatar
What truck, year, model? A problem well-stated is a problem half-solved.
By not starting you mean starter is not turning (cranking), or starter is cranking but you do not hear/feel/smell the VROOM? Please don't throw parts, money and time on a problem unless you have verified what is defective. You may get lucky after a few tirs but still not understand what really and exactly fixed the problem.
See cranking system explained on my sig.
Exactly what is clicking? Starter relay? Starter solenoid? Circuit-Opening relay?
Try this Special Service Tool.
If it makes solenoid click more energetically and consistently cranks the starter, see wiring flaw (click-only) fix on my sig.
If starter solenoid clicks energetically but no crank, it could be bad solenoid contacts.
Best of luck.
Old Jun 11, 2014 | 12:29 PM
JackiesToy's Avatar
1993 toyota pickup 4x4 5 speed 6 cyl 3.0 it will not crank the starter is just clicking, I think we have found the problem, I bought a bad new starter the old one was bad too so we are going to try again. thanks for your help.
Old Jun 11, 2014 | 02:39 PM
RAD4Runner's Avatar
Most welcome, but how sure are you that your bought a bad starter?
Old Jun 11, 2014 | 02:47 PM
JackiesToy's Avatar
had the new one tested read bad
Old Jun 16, 2014 | 05:09 PM
atthegates78's Avatar
I had a similar issue and it ended up being the neutral safety switch..
Old Jun 19, 2014 | 11:34 PM
RAD4Runner's Avatar
Any update? Second new starter works now?
Old Jun 20, 2014 | 05:35 AM
JackiesToy's Avatar
yes went back and got another starter and it cranked right over, running back to normal. thanks for the help!
Old Jun 20, 2014 | 07:56 AM
RAD4Runner's Avatar
Cool!
okamikai
Apr 30, 2018 10:19 PM
Shoua
13
May 22, 2016 05:19 AM
Dakotaneu
Aug 15, 2015 07:24 AM
JHalcyonM
Aug 4, 2015 01:19 PM
Hamonacracker
Jul 17, 2015 08:33 AM
