RAD4Runner's 1986 4Runner dlx Build-up
Old Apr 3, 2013 | 07:02 PM
  #221
Terrys87's Avatar
I know just enough of electricity to be dangerous, or at least enough on how to get shocked. Done that a few times. It is interesting to see how current flows and gets things to working.
Old Apr 4, 2013 | 05:36 PM
  #222
RAD4Runner's Avatar
holy wiring diagram batman!!
Yes, terry and kornhuskerwizard. LOL!
Old Apr 4, 2013 | 06:11 PM
  #223
RAD4Runner's Avatar
Special Service / Diagnostic Tool
DIVIDE AND CONQUER!
The starter solenoid is a good place to divide a cranking issue.
This Special Service Tool Will help you troubleshoot and/or get you started If something keeps power from getting to your starter solenoid coil. I used it to verify what my suspected problem was.
For troubleshooting:
To check solenoid and downstream to starter motor, clutch gear and flywheel,
Disconnect this female spade connector from starter solenoid. (This connnector supplies power from starter relay to the starter solenoid)
Connect RAD's Special Service Tool as follows:
Alligator clip to battery plussitive
Quarter-inch female spade to male spade on solenoid coil positive where you disconnected wire from in picture above.
Ensure safety - manual trans in neutral or auto in park, your tie not dangling near fans or belts, etc
Push button on. Solenoid should clunk, solenoid contacts will close sending cranking current from superthick wire (connected to battery and screwed-on to terminal on solenoid) to starter motor. Motor should turn, solenoid plunger will actuate clutch, engage starter gears with flywheel gears. You should already know how starter alone or starter engaged with flywheel sounds when turning. See what does not do what it's supposed to do, and go from there.
If all from solenoid and downstream works, troubleshoot from that female spade terminal, upstream to your ignition switch.
To start when you know solenoid and downstream is good, but power is not going to your solenoid coil (i.e., clutch switch defective, starter solenoid defective), or not enough power is getting to your solenoid coil (i.e., wiring flaw explained on my thread), and you have no assistant to jump battery directly to solenoid, do same while attempting to start- at the wheel of course.
If you really have to start the engine while you're looking into the engine compartment by yourself, use in combination with the other Special Service Tool - LOL!
Old Apr 4, 2013 | 08:56 PM
  #224
ChefYota4x4's Avatar
Great! Especially the second tool! Now that's some 007-McGuyver-Redbeck ingenuity! Hahahaha. Excellent write up, buddy.... Could be sticky worthy
Old Apr 4, 2013 | 10:29 PM
  #225
RAD4Runner's Avatar
... that's some 007-McGuyver-Redbeck ingenuity! Hahahaha. Excellent write up, buddy.... Could be sticky worthy
Got that right, Mark, and Bear Grylls, too - LOL!
Old Apr 5, 2013 | 10:59 AM
  #226
Hahahahaha,......dude is A SERIOUS die hard! Lol. ....
Remember him sliding down that shale in The Alaskan wilderness, totally cut himself up!
Old Apr 5, 2013 | 12:37 PM
  #227
Philbert's Avatar
I was wondering what the hell that brown plug on my wiring harness was for (putting back together after HG/Head install) - thanks!!
Old Apr 5, 2013 | 01:23 PM
  #228
RAD4Runner's Avatar
LOL!
Most welcome, and LOL, too Philbert! And you were still able to start with that connector dangling?
Old Apr 5, 2013 | 03:43 PM
  #229
Cyberhorn The Dragon's Avatar
Started April Right; Headlight Mod Successful!
To minimize additional parts I rewired the headlight circuit, instead of making an add-on harness.
Stock:
  • Dimmer (combo) stalk switch contacts carry high current for headlights.
  • Wires are thin.
  • Ground circuit goes on thin wires (AWG 18/20?), from bulbs, to cabin, to dash to dimmer switch, back to engine compartment to ground inside passenger side fender (exactly a convoluted path as 4Crawler describes it), causing a lot of resistance, a lot of voltage drops and reducing voltage that ends up across the bulbs.
  • High current (10 Amps on 60-watt high beam, 17 Amps on 100-watt high beams) through dimmer switch contacts will shorten contact life.
As of 1205 Hrs, 01Apr2013:
  • Used only one additional part, a 5-pin relay, plus solder & wiring supplies.
  • Uses existing headlight fuses
  • Upgraded to thicker 12AWG wires, from fuses to ground
  • Ground path goes directly from bulb to relay to fender ground, minimizing voltage drops.
  • Relay carries headlight current, helping extend dimmer switch life.
  • Using normally-closed contact 87A replicates stock circuit for low beam. Even IF relay fails (no power, no ground, or coil open), low beam will still work.
Schematic is here (Slumming with MS Paint 'cause I lost Auto CAD license with upgrade to Windows 7 ] :
Notes:
I replaced all thin stock wire from left & right headlight fuses to positive side (pin 3) of bulbs.
Stock wiring all in black. Red "X" are where I cut stock wiring.
Looking at colored wire:
Basically, I cut off stock wiring connecting ground side of bulbs (terminal 1 for low beam, terminal 2 for high beam) from dimmer switch.
Bulb pin 1 (low beam) was disconnected from dimmer contact "HL" and moved to relay contact 87A, This contact now provides ground to pin 1 to turn on low beam.
Bulb pin 2 (hi beam) was disconnected from dimmer contact "FU" and moved to relay contact 87. This contact now provides ground to pin 2 to turn on high beam.
Pin 5/"FU" of dimmer switch connected to negative side of added relay (pin85).
Operation:
When taillight switch is turned to headlight on, headlight relay closes providing +12V to pin 3 of bulb AND positive side of added relay. Normally-closed contact 87A of relay provides ground to pin2, turning on low beam. (In stock circuit, contact FL of dimmer provided this ground and carried the high current.)
When dimmer switch stalk is pulled to "flash" momentarily or pushed forward to turn on high beam, FU contact of dimmer provides ground to negative side of added relay and turns relay on. Contact 87 closes, provides ground to pin 2 of bulb and turns on high beam. (contact 87a opens and low beam turns off.)
Voltage Drop Comparisons:
With Sealed Beam & Engine off
Stock Wiring
Low Beam:
Batt: 12.05V, Bulb 11.15V
Voltage drop in wiring: 0.9V
volt drop = 7.5% of battery voltage
High Beam:
Batt 11.94, bulb 10.07
Volt drop: 15.7% of battery voltage!
After Retrofit:
Low Beam:
Batt: 12.31V, Bulb 12.11V
Volt Drop: 0.2 = 1.6% of Battery voltage
High Beam:
Batt: 12.24V, bulb 11.78V
Voltage drop: =0.46V = 3.75% of battery voltage
Still To Do:
High beam indicator circuit TBD after I find junction as noted on schematic.
keyword search H4 conversion, H4 convert
saw this an a page i looked at recently popped up in mind
http://revlimiter.net/mods/lowpro.php
shows where to feed power from back to the high beam indicator with a diode
likely im not bein much help but..
Old Apr 5, 2013 | 04:10 PM
  #230
RAD4Runner's Avatar
the mod on the link is similar to the drop-in H4 harness conversion - relays' are being added. Diode does something else.. something about preventing both High beams and low beams from coming on at he same time.
-RAD
Old Apr 5, 2013 | 04:27 PM
  #231
Philbert's Avatar
LOL!
Hell no! I don't even have the upper intake manifold on yet - wanted to make sure I got all the wiring plugged back in right first
Love your writeups - going to use yours for the H4 harness upgrade soon.
Old Apr 5, 2013 | 07:40 PM
  #232
Co_94_PU's Avatar
-RAD
Symbol is backwards I think. assuming it turns the low beams on with the high beams. *cough*violates FMVSS*cough* all though I did check and it's legal in Colorado to have 4 beams on at once *shrug*
I'll get to this relay mod eventualy, If I go the right day the salvage guy will probably let me have relays. Just gotta show up when he's busy tearing something apart and doesn't want to walk all the way back to the office to write me up a receipt.
Old Apr 11, 2013 | 06:57 AM
  #233
Redeth005's Avatar
Hey Ray. Have you taken before and after shots to aee thw difference with brightness on your headlights? Maybe I might have missed it. But I don't hink so. I'm just curious to see how much of a difference it makes.
Old Apr 11, 2013 | 07:38 AM
  #234
RAD4Runner's Avatar
Sorry, Richard, I was not able to take before and after. However, I can really tell the difference. It's not as yellow and dim anymore. Numbers I posted can be used to calculate how much extra power bulbs Re-gained and that can be converted to light output (just don't have time to calculate).
BTW, a drop-in harness will have slightly better performance than my method because you'd be taking power directly from battery, bypassing the main fusible link and network of fuses.
Now I'm ready to install the AutoPals
Old Apr 11, 2013 | 08:59 AM
  #235
Redeth005's Avatar
All good. I forgot to take height measurements on my truck before I started the sas/lift too. Lol sometimes we jist wanna hurry up and jump on the project that we forget stuff we wanted to do as a reminder of how much of an upgrade we got in the end
Old Apr 11, 2013 | 08:21 PM
  #236
RAD4Runner's Avatar
Mis-Aligned Clip/Bracket On Overload Spring
Hi I just found this bracket on my left hand side overload spring mis-aligned, and it's probably causing squeaking when I start from full-stop or shift in lower gears.
UPDATED 20130421:
Fixed, guys! Thanks for your ideas.
I merely placed jackstand under frame, jack under rear axlle near spring seat, removed wheel and lowered axle to relive weight on spring pack. Loosened U-bolts and tapped overload spring to line up properly. I did not notice sign that axle shifted on leaf pack. Bracket has obvious wear where overload spring had been rubbing on it (see step in pic below). Overload spring must not have been installed properly in the first place. I hope that fixes the squeak I've been hearing since I did the Zuk.
Old Apr 11, 2013 | 08:23 PM
  #237
Philbert's Avatar
Whack it with a BFH to align to taste
Old Apr 11, 2013 | 08:29 PM
  #238
RAD4Runner's Avatar
Does it have to be a calibrated BFH? LOL!
In Naval aviation technical training school, we had a multiple choice question asking what you use to install a starter's rectifier diodes. One of the choices was BFH. - LOL!
Old Apr 11, 2013 | 08:39 PM
  #239
Bfh'd many a starters with a sticky solenoid. I would do just as Phil said. That happened when hitting the perfect mix of relief of the overload in a nasty turn or something. BUT, I only would add that u wanna seee if ur u bolts have become tweeked or backed off.... NOT EVEN CLOSE to likely, but just check.
Old Apr 11, 2013 | 08:56 PM
  #240
RAD4Runner's Avatar
... u wanna seee if ur u bolts have become tweeked or backed off.... NOT EVEN CLOSE to likely, but just check.
Thanks, Mark. Will check that. I also notice that truck now pulls to the left- while it never did for months since I first got her. Maybe happened when I went out to Blair/Little Blair Valley last November.
