Rain leaking under glovebox while driving
Old Jun 11, 2014 | 10:34 AM
hiluxhack's Avatar
1994 hilux has a drip that occurs only while driving in the rain. It drips on the passenger side, under the glovebox. It just misses getting the ECU wet but the A/C relay catches hell. I've replaced it once. Now I know why it failed. I can't find a leak around the windshield, and it's not condensation from the A/C. Has anyone had water coming from inside the fender well?
Old Jun 11, 2014 | 12:07 PM
RAD4Runner's Avatar
Water splashing through the hole where antenna goes into the cab? where wiring harness goes into the cab? Rust in the cowl area?
Old Jun 11, 2014 | 06:57 PM
mmetzgier's Avatar
mine is leaking from the middle of the bottom of the windshield. its making it drip from behind the glove box. good thing for the huskee liners.
Old Jun 12, 2014 | 12:51 AM
hiluxhack's Avatar
The truck can sit parked in pouring rain with no leak, but start driving and it leaks.
Old Jun 12, 2014 | 02:23 AM
Terrys87's Avatar
Look inside the cowl in front of your windshield and see if there is alot of debris there. I seen one with a rust hole from trash sitting there. You will need to remove your wiper blades to remove the cowl.
These trucks are known for getting rust around the windshield. I had to have a windshield pulled and cleaned the channels where it sits and seal it up to fix it.
Old Jun 12, 2014 | 08:39 AM
mmetzgier's Avatar
mine is fine also when its parked. i know mine is the window seal tho.
Old Jun 12, 2014 | 12:23 PM
hiluxhack's Avatar
Thanks for the advice. I'll take the cowl off this weekend.
Old Jun 22, 2014 | 08:35 PM
hiluxhack's Avatar
Hey thanks to all who offered advice last week. I took off the cowl and saw a twisted looking area of the windshield gasket I used some clear spray sealant with several passes after dry each time. No more leak!!
I really appreciate all of you and how willing everyone is to help.
Old Jun 22, 2014 | 08:38 PM
hiluxhack's Avatar
you nailed it.
Thanks to your advice, I went right to the problem. I appreciate you taking time to help. Thank you.
Eggslinger
Jun 8, 2019 03:32 PM
andrewtexas123
Jul 14, 2015 04:29 AM
nick b
Jul 11, 2015 04:38 AM
Kluch8651
Jul 9, 2015 10:39 AM
Avenged
Jul 9, 2015 07:55 AM
