Aftermarket gears in factory 4.88 3rd
Old 07-01-2014, 08:08 AM
Edionne13's Avatar
I grenaded a 4.88 rear yesterday and someone could rebuild it for me but I thought you can't put aftermarket gears in the 4.88 thirds
Old 07-01-2014, 08:10 AM
MaK92-4RnR's Avatar
You can't. lol factory 4.88s must go in a factory 4.88 differential.
Old 07-01-2014, 08:13 AM
JasonYota's Avatar
^^ this.
Old 07-01-2014, 08:16 AM
Edionne13's Avatar
Okay that's what I thought it can't be done. Thanks for the confirmation
Old 07-01-2014, 08:23 AM
JasonYota's Avatar
How did yours grenade? Do you have a locker?
Old 07-01-2014, 08:26 AM
MaK92-4RnR's Avatar
factory 4.88s are not very strong. its typical. I ran mine with lockers and they were fine with 33s.
Old 07-01-2014, 08:44 AM
Edionne13's Avatar
Is that the issue because factory? I would assume the quality is there from Toyota but guess it failed. What's the reasoning aftermarket gears won't fit the 4.88 housing? I'm running only 33s
Old 07-01-2014, 08:57 AM
JasonYota's Avatar
I believe it's the offset inside the 3rd that's different to any other toy diff. Gearinstalls.com should have some info about it.
Old 07-01-2014, 08:59 AM
JasonYota's Avatar
First I've heard of this. I plan on putting some power though mine. I'll see if it holds...
MaK92-4RnR's Avatar
the factory 4.88 is a thinner ring gear. the aftermarket 4.88 that you would put into a 4.10 or 4.30 diff is the same thickness, I believe.
Old 07-01-2014, 06:30 PM
Edionne13's Avatar
No locker I was just driving in town only on 33's also and searching for another 4.88 diff is insane to find
Old 07-01-2014, 06:50 PM
JasonYota's Avatar
I've seen them come up for sale in the classifieds time to time. Did a bearing let go or the actual ring and pinion break teeth off?
Old 07-01-2014, 07:22 PM
Edionne13's Avatar
Teeth few chipped and pinion is shot.
smthwsn357
12-04-2023 02:08 AM
XtraCab
04-12-2020 05:25 AM
mskalmus
05-28-2017 07:51 AM
jerusry
10-19-2015 05:28 PM
deepmarsh
08-06-2015 03:44 AM
Quick Reply: Aftermarket gears in factory 4.88 3rd
