a/c relay
Old Jun 19, 2014 | 04:32 PM
skillbill's Avatar
Exclamation a/c relay
my a/c wont blow cool air at idle.my uestion is where is my a/c idle up relay located at and how do iI adjust and or test it.This is on a 91 4x4 22re.Thanks
Old Jun 20, 2014 | 01:43 PM
skillbill's Avatar
Help its getting real hot in
The deep south!!!!!
Old Jun 20, 2014 | 01:53 PM
vital22re's Avatar
totally a bro
If its a truck you're kinda stuck. 4runners run a small fan in front to help push air through the condensor. Otherwise you're looking for the ac amplifier.
Pull the glove box and and follow the wires on the heater box. There will be the amp with a single connector to it. It will have a dial you can adjust for the kick on idle. There may be an ac idle speed valve on the intake manifold. Google search it for images.
Old Jul 13, 2014 | 08:49 AM
tsh2014's Avatar
See my last post here, total cost to fix was less $90: https://www.yotatech.com/forums/f116...issues-281702/
I have the same truck year as you and had the same problem. The idle up is at the top right hand corner of your Cooling Unit. This is the large black box looking thing you see when you remove your glove box to the left of your blower fan. The switch is actually a turn twist knob, it is black as well. When you remove your glove box assembly, turn your blower on and if it does not work in low, change the blower resistor. This is located at the bottom rear of your fan, follow the black taped looking wire.
I never touched my idle up/down switch. Just replaced the parts mentioned in my thread.
Let me know if you have any questions.
Badlander
Oct 10, 2015 08:05 PM
bradahman
Oct 1, 2015 09:24 AM
bryan34w
12
Sep 30, 2015 02:50 PM
beltcutter
Sep 30, 2015 06:14 AM
JPV
Sep 28, 2015 03:15 PM
