Truck had a poor 22re to 22r swap need help
I have a 91 toyota I bought for a toy truck it came with 22re efi but they had swapped it with a 22r carb from a older truck. Doesn't look to be done exaftly right and has to have a switch to turn fuel off and on that's running striaght from the battery. And just did plugs, wires, oil change, clean fuel tank and checked lines, also changed PCv valve and changed dist. Cap and rot button. Ran good but had a bump in the idle. Drive t for a week with no problems. Then parked it one night now will try and start but won't fire just floods, has tried to fire a couple times and even started once but quickly died out. Any suggestions would be great. Have the Haynes magazine but doesn't tell a good spot to start without sinking a lot of money as I didn't give much for the truck don't want to dump 100s in it trying to fix when someone might now easier and cheaper things to start checking.
91 22r 4wd 5spd single cab.
a carb on a small engine doesnt need more than 3-4 psi. i think the original pump puts out 40+ psi.
then again, it might be something as simple as a bit of trash in the needle and seat preventing the needle from seating and shutting off fuel flow.
btw, you have my dream engine swap. i have the 22re and have had a bunch of injection problems. it's running good now but i'd much prefer a carbed engine.
sounds like the float is stuck in the down position. if they are still using the original fuel pump and DO NOT have an aftermarket fuel pressure regulator installed then the needle and seat just cant stand the excessive fuel pressure.
I know that much but it's been days and I've let it sit to get unflooded and I've checked all the plugs I even replaced 3 of them. Not saying the carb isn't messed up but I don't think the reason it's not starting is because it's flooded it keeps flooding and not wanting to fire for some reason.
if you got no fire its time to take the whole trk to the shop.
Went out this morning to try and work on it but figured id try starting it just for the hell of it. And it fired and ran for a about 3 seconds and was even able to rev it then it die out and wouldnt start back. It had an oil leak prior to all this i think this was due to the poor engine swap looks like the used some red gunk to seal the pan to the block but now its leaking gas/oil mix and i know its gas and not water like a blown head gasket because i can smell the strong smell of fuel. Any ideas what this could be or if it came from over flooding the truck out and cylinder full of fuel and when i let it sit that its drained down them and seaped into the oil pan?
if you have fire the carb needs to go to the shop
if you have gas in the oil, it must be changed or your bearings will be toast.,
Yeah it won't start so I def won't try again until after I change it. Idk it was a bad gasket on the oil pan or what because it's got like red apoxy looking stuff all the way around and what would cause oil in there like that. Could it be from flooding it 3 or 4 days in a row or is it something bad. But I'll def take the carb off and have it looked at.
Yeah I'll def put a new gasket on it when I change the oil for sure. Just want to fix the gas in my oil problem first so I'll have the carb out and take it to get looked at
GreenLion
06-07-2021 10:49 AM
