- all pro front bumper
- 93 4Runner - washed engine, now it dies 3-5 sec after start
- Replacing Rear Main
- squeaking noise...
- 3.0 Dual Case question
- Changing CV....question on first step :(
- FINALLY New tires and SPOOL installed!
- Steering Stabilizer?
- suspension lift questions
- 93 4Runner stalling out
- soon to lift.
- Beefing up front IFS
- truck wont turn over. please help!
- cowl hood?
- motor clicking
- Oil Filter Problem
- 22re compression ratio
- my newer front axle what should i look for?
- 88 4Runner - Heater Core Change?
- Trouble with manual hubs, was I scammed?
- 94 4runner 4x2 driveshaft vibration
- stripped cam cap bolts
- my dream truck
- Where is the VSV related to the A/C located?
- portal axles
- removing bed from frame
- 22re head
- Good place to buy some seat covers?
- Pictures of my 88 small block sas 4runner
- Washed engine now issues please help
- Ripple voltage on O2 sensor???
- is this a good Suspension Lift Kit
- 95 pickup overheating... headgasket??
- baffled oil pan
- Pinion Oil Seal?
- Which shackles should i get? 93 4x4 P/U
- Aussie Locker install question
- 3rd gen front e-brake cable?
- 22re Alum. radiator
- Clutch leak
- Do NOT Buy A Gorilla Winch.
- lock ot hubs?
- i need help with a isr mod
- Is my head gasket blown?
- Check out this 90 Toyota truck
- HiLux Badge
- My ISR/Deckplate (Pics inside!)
- Stripped Head bolts please help!
- Leaf bolt?
- Front end shimmy in 4x4
- O2 Sensor Brand - Whatcha think?
- weather stripping holders
- which torque converter goes with 340H?
- Valence Substitution Suggestions???
- it will turn over but wont start
- 87 22r fuel filter location
- Painting my 88 truck
- New to the forum, just bought a beater 1990
- Changing belts
- synthetics....
- Need some diff help
- To EGR or not to EGR, that is the question...
- Welded Front with ADD
- So, is this rod knock? Audio clip included
- 86 fuse problem
- Modifying Kayline 4runner Soft top
- rocker panel replacement?
- new fuel saving performance package!
- Mazda Rims...
- Whats this?
- Adding leafs?
- Vacuum hoses?
- Window Stick To My 86' 4runner
- Gauntlet revisited
- Another oil cooler question
- 4Runner kaput
- I got a question about wiring on 90 4runner
- Lift and Tires question??!
- Ignition Switch
- Brake pedal to the floor?
- looking for this part!
- 3" body lift???
- instrument panel part number
- wiper malfunction?
- 1989 Toyota Dually (lots of pics)
- Help!!! Losing 1st gear in 5spd tranny
- 94 Pickup Won't Hold Position on Hills?
- In need of some help..NO Brakes...and missing Tube
- Final 5 speed swap questions 22re
- Overdrive kit for my '87 1-ton 2x4
- 88 P/U IFS 22RE w/ 33's...what should I regear to
- clutch squeak?
- Here my 87 4Runner Soon to BE BAD!!
- How do you know a motor mount is broken?
- installing a 2" PA body lift
- Anybody for NY or NJ
- Law on tube door question
- What size is the threaded hole for the oil press. sending unit ?
- airbox restriction hurting accel?
- REAR WINDOW, Not coming up straight
- How hard is it to pull this off?
- Adding cruise?
- Overdrive intermitent
- 87 4runner possible head gasket leak
- Marlin Crawler rear bumper question!?!?
- 22re to 20r
- Today was a damn good day!
- another 22re swap question
- Two pinion, how can you tell.
- can i flip the hitch for more ground clearance?
- Need diagnosis of drivetrain problem
- T-case/Driveshaft leak
- Another braking problem!! please help!
- Rocker Panels (replacement parts)
- Ok, opinion time......
- Can anyone identify this part?
- Toyota radiator coolant shelf life?
- how to break in a new head
- Question bout shocks
- Tons of poser pics (dial-up beware)
- 1994 4Runner 3VZE (Auto)
- Hood and Hood Bracing
- Rear Anti-Lock Brake Light
- Code 71, 22re Help Im away from my shop.
- Light Bar Fab
- Rear End Sos!!!!
- '87 4runner gas mileage drop..need help
- 93' 22re a/c conversion???
- Can someone post a pic of a 2'' BL
- Will a 86' rear window fit in a 93'??
- EFI conversion help
- a/c
- 1990 4Runner questions
- new off road lights, mud flaps, and cv c-clip eliminators
- Question about blown head gaskets
- Need help on 22re!!!
- Shifter Help
- I got questions about switching v6's mines blown
- New BEAST!!!!!
- IFS: Snap ring on CV axle new or re-use?
- Driver side,inner door panel removal question
- Looking for the best price!!
- hood Mount Snorkel/ram Air
- 80 Amp fuse
- 1991 4runner 22re overheating problem
- Window trim restoration
- Upgrading suspension in 2wd runner
- 94 5 speed manual trans question?
- Duplicolor: thumbs up!
- headgasket
- R12 OR 134a
- Aftermarket center console?
- Check it out!
- Double up skid plates?
- 1988 3.0 timing belt
- Bigger shocks without modification?
- name this part!
- Starting issue. Sometimes it just won't start. Need serious HELP here!
- Should I buy one of these 4runners?
- So much for my nice new truck!!!
- Painting the rubbery piece in front of rear fenders
- Seafoam!
- 22 wont fire pics inside!
- idling high
- Dash Pot?
- Replaceable parts
- Rebuild of 3vza but what sizes?
- Just failed WA emissions. Any ideas?
- Idler Arm Brace for non stock I-arm?
- trailer wiring?
- 31's Rub on BJ Spacers?
- No power, loss of electrical power.
- A/C doesn't blow cold at idle. Need help
- Water Pump Or Rad?
- Is it possible to use a class 4 hitch?
- Race Muffler!
- my 88 4runner
- Cluster connector for speedo?
- Dead Battery Again
- rocker panel?
- MAF Cleaning
- piston ring dumb question!
- 1994 Toyota Pickup Transmission Problems
- Air Valve location, 85 vs. 89?
- where is the afm cog?
- Emergency brake mayhem
- Right rear brake not pressurizing
- How Can I Paint Certain Interior Pieces To Match?
- Oil filter confusion
- Low Idle ONLY when warm an in gear!?
- Were is the knock sensor?
- Help - oil leak
- cold start issues - tried everything
- New style front on older yota?
- 4runner frames
- Installing a 22r engine
- Negative Pressure Alcohol Injection
- 22re clutch
- Finished parts truck!
- A/c Evaporator Cleaning
- '91 4Runner V6 "Fan Shaft Housing Assbly"
- Does this seem ridiculous to you?
- '84 2WD rear diff' on '87 4WD
- Whats the best way to lift your front end?
- CV Ball Bearings placement
- whats the thread pitch on the 22re head bolt thread?
- I Think My Rear 3rd Is Toast
- trying to upgrade the alt wire but...
- Tranny/Engine Oil Cooler Combo: Anyone???
- Power steering pump- question about the vacuum lines
- i want to remove my intake silencer
- What are the steering wheel buttons for? Seats from a 92 to a 94?
- 3.0 Cat Removal
- ah getting paid to work on my truck!!! lots of pics
- Flat towing w/an automatic?
- A/C Compressor Not Turning On
- its out so what should i do?
- Dirt bike carrier springs/shocks help
- chevy/cadillac alternator
- Dual Battery Install
- Lookin for a good vendor for 3.0L V6
- What symptoms really warrant valve adjustment?
- POLL TIME!!! What would you do?
- Cup Holders!
- steering shaft
- Downey 2" lift springs, Whos got 'em?
- timing way off
- engine wont start!!!!
- Attarco Head???? Anyone heard of them??
- Timing help
- PS fluid put in my PS Pump instead of ATF!
- water outlet on bottom of intake manifold SUCKS
- Me in MODIFIED CLASS?
- doing my 3rd tomorrow questions....
- Installing New Head...have a couple questions......
- summer fix: frozen washers
- 33 Inchers on an 88' 4Runner?
- Checking for drain on Battery??
- 22re engine expertise needed
- Replacing Wheel Cylinders
- missin and can't find my way
- rtv sealant for the 3rd!!!!!!! need to know asap!!!
- speedometer works, odometer doesn't??
- Help With 4WD Problem
- Help
- how to adjust the valves with a 3VZE motor
- 22r hot rod
- Head gasket
- tranny difference, 89 pickup vs. 88 4runner, which is better?
