Can anyone identify this part?
Old Jun 23, 2008 | 11:00 AM
Cyberman's Avatar
Can anyone identify this part (V6)?
It is to the left of all the VSVs. It has a hose that is looped to itself.
Old Jun 23, 2008 | 11:16 AM
Swansen's Avatar
is that the idle up valve???
Old Jun 23, 2008 | 11:25 AM
thook's Avatar
Yep.......
Old Jun 23, 2008 | 11:32 AM
Swansen's Avatar
Originally Posted by thook
Yep.......
WHATEVER, I DON'T WANT ANY OF YOUR ATTITUDE!!!!
(just kidding, just kidding)
Old Jun 23, 2008 | 11:41 AM
thook's Avatar
Aaaawwweee!! Give us a w'ittle kiss....
Old Jun 23, 2008 | 02:31 PM
Cyberman's Avatar
Okay, anyone know where it normally plugs into? The hose literally loops around to itself.
Old Jun 23, 2008 | 04:12 PM
thook's Avatar
On my '92 4rnr, it's for the A/C. I'm sure it is for you truck, as well.
You have the idle up valve and the vacuum switching valve. As far as I know, it's not hooked up the A/C at all, but should route somehow to the intake plenum....as far as the vac lines go. I'd go reference my vehicle right quick, but the wifey-pooh just took off in it to town. It'll be several hours before she gets back. Hopefully some other YT bumb around here will help you out.
Come on dudes! It'd take ya five minutes!!
Old Jun 23, 2008 | 04:13 PM
thook's Avatar
Wait...wait. I looked at the pic and thought about it. What you have circled I'm pretty darn sure is routed correctly. The longest line running from the valve goes to the plenum.
Old Jun 23, 2008 | 05:24 PM
leo the lion's Avatar
Idle Up,.
Old Jun 23, 2008 | 05:58 PM
Cyberman's Avatar
I know the vacuum lines are attached correctly, I never pulled them off. What's getting me are the 2 larger hoses (going behind the evap canister) that are puzzling me. The 2 hoses connect to each other with a short piece of vacuum tubing. It was that way when I got the truck. I have a bookmark of someone else's engine swap with plenty of pics, but they don't have one (they don't have A/C).
Old Jun 23, 2008 | 06:08 PM
Cyberman's Avatar
Okay, I found the routing of the hoses. According to this diagram, one of those hoses is supposed to go to the air intake, and the other is supposed to go into the plenum. Mine are connected together in a closed loop.
Somebody show me where they are really supposed to go.
Old Jun 23, 2008 | 06:32 PM
thook's Avatar
If it can wait, my wife will be home in about an hour.
Old Jun 23, 2008 | 06:45 PM
Cyberman's Avatar
oh, it can certainly wait. My truck probably won't be turning over for another month or so lol.
Old Jun 23, 2008 | 06:50 PM
91Toyota's Avatar
then some spanky spanky...
Old Jun 23, 2008 | 07:00 PM
thook's Avatar
Lol.....hey, hey! That's nunner yer buziness!
Old Jun 23, 2008 | 07:04 PM
91Toyota's Avatar
^ Not if Kirk was filming it
Old Jun 23, 2008 | 09:07 PM
Swansen's Avatar
HAHAHA.... ok, not here to guys..... But really???? what is the deal with people and vacuum lines??? Why does everyone insist on routing everything all screwed up, i literally, think people just plug in hoses where ever they see fit until it runs something like normal, and there like yeah, ok. ????
Old Jun 23, 2008 | 10:21 PM
Cyberman's Avatar
I'm not at the routing part, and I'm sure I'll get it right the first time. Some people have trouble with hoses, just like people have trouble with wiring. Have you seen how many vacuum lines are on the 3.0? I've never run across so many vacuum operated controls in my life.
Forget the initial query. I found out I was looking at the wrong set of hoses. But, I do have a pair of hoses that loop, with a vacuum pipe at the one end. Anyone know where this goes? I can take a pic if needed, but they are similar to the ones used on the idle up valve, maybe slightly longer.
Old Jun 24, 2008 | 01:09 AM
just a 22re's Avatar
vac lines my god just cap them all off you dont need them!!!!!!!! even the fuel lines you dont need them too for that mater the 3.0's run on love so drain that paper weight called a gas tank and send me what ever you find inside of it ill pay shipping lol
no really though vac lines are funny they go from here to ther back over here then splits over to there and before you know it you go one big rubber rollercoster under your hood as for the loop toyota used the same parts for the high end model as for the chepostake model i guess you just dont have what that goes to so id say dont worry about it
Old Jun 24, 2008 | 02:27 AM
scuba's Avatar
shood id say that 3.slooo would be good without the coolant lines too
