Can anyone identify this part?
Old Jun 24, 2008 | 03:02 AM
thook's Avatar
He started it, Swansen.
Originally Posted by Cyberman
I'm not at the routing part, and I'm sure I'll get it right the first time. Some people have trouble with hoses, just like people have trouble with wiring. Have you seen how many vacuum lines are on the 3.0? I've never run across so many vacuum operated controls in my life.
Forget the initial query. I found out I was looking at the wrong set of hoses. But, I do have a pair of hoses that loop, with a vacuum pipe at the one end. Anyone know where this goes? I can take a pic if needed, but they are similar to the ones used on the idle up valve, maybe slightly longer.
Right....just as I was feeling a tad guilty for falling asleep, too. <<(and, no comments from the peanut gallery....please)
Yeah, get some pics. The 4rnr's home and I can help route whatever you need today.
Old Jun 24, 2008 | 08:35 AM
Cyberman's Avatar
Okay, here are some pics of it. I'm sure when I'm done getting things together it may become evident where it goes. I'd like to know ahead of time though, if possible.
Old Jun 24, 2008 | 10:07 AM
just a 22re's Avatar
looks like my power steering idle up lines just blocked off all cool like lol
Old Jun 24, 2008 | 11:29 AM
Cyberman's Avatar
I think you're on to something. Underneath the power steering fluid reservoir, on the left and below, is that where the hoses go? If so, I've got a busted air valve.
Can anyone take a pic of that location for me?
Edit: I found a pic, and I do have a broken air valve. The plastic ports are knocked right off.
Old Jun 24, 2008 | 11:46 PM
  #25
thook's Avatar
Hey.....take a pic of your broken valve. And, get a part number. I might have one, if you'd like.
Old Jun 25, 2008 | 12:13 AM
  #26
Team420's Avatar
Yep...they look like the ps pump vsv lines to me. I got one from a pick and pull for $10, could have had the whole pump for $25
Old Jun 25, 2008 | 07:38 AM
  #27
Cyberman's Avatar
It's definitely a broken valve on the pump. Dealership wants $97 for one new. I might go to the local yard and see if I can get just the valve (this yard is kinda pricy sometimes).
Old Jun 25, 2008 | 12:16 PM
  #28
Team420's Avatar
If you cant find one...search dirtoyboy on yt, I bet he'll have one, and he has good prices from what I can tell.
Old Jun 25, 2008 | 01:53 PM
  #29
thook's Avatar
Umm.... I might have one that will work for your truck. Just need a pic and/or part number to see if it'll match up. I'll make it cheap, too....
Old Jun 26, 2008 | 09:50 AM
  #30
scope103's Avatar
Cyberman -
Did you ever get this figured out?
Your photo shows the AC idle up valve. When the AC is on, the valve is opened, and connects the two hoses together. The hoses are supposed to be connected to the air intake and to the plenum (see diagram below); when the valve opens it allows a little extra air into the plenum which raises the idle. Connecting the two ends together as shown doesn't do anything. If the port on the plenum where it is supposed to be connected is not capped (or filled with crud, same thing) then you're idling a little fast (or, put another way, when you plug that port your idle will drop, and you may need to adjust it.)
Same deal with the power steering pump, though it sounds like you're missing that one too. On the power steering pump, when the pump is really straining (like if you turn the wheel all the way to the lock and keep pushing), that valve opens up and raises the idle. Otherwise, you could kill the engine trying to get out of a tight parking space.
If these port are just left open when the hoses were pulled, you've already turned your idle up all the time. Not good in the days of $4.50/gal. Or, someone pulled the hoses and capped the ports. Or, pulled the hoses, and then turned the idle back down (but losing all "idle up" capability). Whatever: when you get this stuff hooked back up you'll need to check where the idle speed ends up.
But first: when you find the port on the plenum, put your finger on it while the engine is running. Does it suck? It's supposed to. Because of the EGR (and other things) the plenum tends to fill up with a startling amount of crud. I had all the vacuum lines hooked up, but never really noticed the idle-up. When I did a top-job (blown head gasket), I spent a lot of time cleaning out the plenum. Voila! Idle-up was now evident!
Good luck!
Old Jun 26, 2008 | 09:56 AM
  #31
Cyberman's Avatar
Yes, I got everything squared away with the hoses. I didn't get a replacement valve for the power steering, but got it back together.
Old Jun 28, 2008 | 02:01 PM
  #32
misterzee's Avatar
I think this vacuum line requires the BRUSH ATTACHMENT ...
Old Dec 22, 2008 | 06:08 AM
  #33
smartboyalex's Avatar
Just to add in on this one... DONT EVER BUY A MERCEDES. everything on it operates off of vacuums. From the A/C switches to the Headrest. My mom has one and has had me check stuff out on it and I have no clue where to start. If you hate vacuum lines don't get a mercedes.
88sasturbotoy
Jan 30, 2026 01:57 PM
mskalmus
May 28, 2017 07:51 AM
May 20, 2016 10:27 AM
rushw
Jul 18, 2015 01:46 PM
Fundy Rider
Jul 16, 2015 01:35 AM
