trailer wiring?
Old Jun 21, 2008 | 12:43 PM
1992toyota4x4's Avatar
trailer wiring?
hey guys, i want to run a completely new wire harness for my trailer, cuz the harness i have goes to a box in the back, and so many wires are cut, or missing or all over the place. so i bought 25ft of trailer wire 4 prong, so i know that the white is ground. it says that the green wire is for right stop, and turn. so do i wire the same green wire to my brake light and also my turn signal? how does that work? cuz on my father in laws mazda pickup, hes got the amber turn signals, and he has a 4 prong harness, and it works fine, im just not sure how to do it. thx
p.s i searched previous threads, and none explain how to wire it yourself, only to buy the connector, but mines so ed up i dont think it would work.
Old Jun 21, 2008 | 12:51 PM
DeathCougar's Avatar
Buy the plug and play kits they sell for your truck, and be done with it. Fast and clean install, and you know its done right the first time.
Old Jun 21, 2008 | 12:53 PM
... i just said i dont want to do that.. can some one explain how to wire it plz
Old Jun 21, 2008 | 12:59 PM
abecedarian's Avatar
whether you want to do it or not...
you have to get a trailer wiring converter/adapter
... or ...
wire the trailer with separate turn signals and brake lights and a 5 conductor connector.
No other way around it...
the 4 conductors plug:
1 left turn/stop, 1 right turn/stop, 1 marker/running lights, 1 ground.
your truck:
1 left turn, 1 right turn, 1 stop, 1 marker/running lights, 1 ground
you would require 5 wires (without the converter) and the trailer lighting done appropriately
Old Jun 21, 2008 | 01:02 PM
otherwise, if you're really stubborn, you can either wire the connector to flash the appropriate light on the trailer with your turn signals and not have brake lights, or have brake lights and no turn signals.
Old Jun 21, 2008 | 01:04 PM
and get pulled over and given a hefty ticket for faulty equipment
Old Jun 21, 2008 | 01:07 PM
yeah, DC. I forgot about that.
on another note, sometimes you can get away with a trailer that only has night-time markers and reflectors if the tail lights on the tow vehicle can be clearly seen from behind the trailer, so the trailer has to be either very low or narrow.
Old Jun 21, 2008 | 01:11 PM
you did NOT say you didn't want to do that, you merely said wires were hacked up and went to a box.
First thing I would do, is yank any non-stock wiring out, and repair all the wiring harnesses back to stock. THEN buy the connector harness, and do it right.
The previous dummy who messed everything up did it by trying to wire it the exact way you are planning on doing it. If you dont know anything about wiring and circuits, why are you going to mess with it? Just do it right the first time with a connector kit and be done with it.
Old Jun 21, 2008 | 04:07 PM
ya sorry for all the confusion, im gonna get the converter, the one i have now only outputs on the left turnsignal/brake, so its messed up, i figured out how they wired it, they had half on the original wiring, and some wired direct. im going to keep the direct and get a new converter, u can get them at canadian tire and wal-mart?
sorry for being cranky guys, i slept 1 hour last night, had to drive my sister to the airport, so to who ever i was bitchy with sorry. thanks for ur help
Old Jun 21, 2008 | 04:16 PM
WEINERDOGBONE's Avatar
I'm not sure that you can buy just the converter any longer. Mine just failed and I had to order a whole new T Connector from NAPA to get a new converter. I spoke to 6 different auto parks stores and they all looked at me like I had horns. NAPA was the only store that knew what I needed and they said I had to buy the whole harness to get it. Good luck.
Old Jun 21, 2008 | 06:34 PM
generically speaking, you'd need a wiring converter for european vehicle to american trailer, or for separate turn signals and brake lights to common turn signal and brake lights.
every auto parts store around me sells them- autozone, kragen (schucks), pep boys, bap-geon, napa, etc., wal-mart, lowes, home depot....
Old Jun 22, 2008 | 05:40 PM
TORTIS's Avatar
plug in play. 15 minutes and your done w\install.
Old Jun 23, 2008 | 04:35 PM
Noltz's Avatar
Go to Canadian Tire and ask for a trailer wiring kit for your truck. Tell them it needs an integrator box. It converts the separate turn signals (4 bulb) from stock to American 2-bulb style. They run about $35cdn.
There is the option of getting a unit that draws power directly from the battery. If you do this, make sure that you add a fuse near the battery. There isn't one in the kit until directly at the converter box... not safe. I've personally seen one fire from that wire, and heard of 3 more.
sanctfy
All Other Toyota Swaps
Sep 15, 2015 02:52 PM
58rennur4
Aug 4, 2015 08:49 AM
defrag4
Jul 31, 2015 10:50 AM
shadowbirdie
Jul 21, 2015 10:38 PM
toyota32
Jul 6, 2015 05:42 PM
