4runner frames
Old Jun 19, 2008 | 07:51 PM
4runnerguy's Avatar
4runner frames
what would u guys suggest to clean the dirt from the inside of the frame. I have a 91 4runner
Old Jun 19, 2008 | 08:00 PM
4runnerguy's Avatar
any one lol
Old Jun 19, 2008 | 08:30 PM
CJM's Avatar
CJM
Pressure washer, wait for it to dry a bit. Then take a good quart of oil or two and dump it in and go driving.
Old Jun 19, 2008 | 09:14 PM
4runnerguy's Avatar
bump bump
Old Jun 20, 2008 | 05:33 AM
4runnerguy's Avatar
u guys got any more suggestions on how to take dirt from the inside of a boxed frame
Old Jun 20, 2008 | 05:38 AM
waskillywabbit's Avatar
Why?
Pressure washer.
Old Jun 20, 2008 | 05:42 AM
4runnerguy's Avatar
cause there is alot of dirt inside and i dont want it to rust
Old Jun 20, 2008 | 07:48 AM
corax's Avatar
pressure washer from the open end of the frame rail at the back, stick the nozzle in any of the open holes along the frame rail, etc.
My problem is hay/straw in the frame rails (from a mouse maybe?), I thought about burning it out, but then I got sober and ditched that idea
Old Jun 20, 2008 | 08:09 AM
4x4mike's Avatar
Guest
Lots of water from the back of the frame. I've only been in the mud a few times but when I wash the 4runner dirt comes out months later. Check at a dealer that does the under coating for new cars. The place bought our Subaru at had a way of coating the inside of the frame on some vehicles. I think it was just a curved wand that they stuck in holes.
They make this stff for bicycles called frame saver. It's for steel bikes. It protects the bike from rusting from the inside out. I think it's 3M that makes this tool protectant for tooling and lathe/milling tables. You spray it one and it leaves a layer of protectant that will stay on for up to 2 years. I don't think it would last that long on a vehicle frame plus I think it'll attract dirt.
Old Jun 20, 2008 | 08:16 AM
CJM's Avatar
CJM
Uh thats you use the pressure washer, then waiting for it to dry and the oil is for?? You cant paint the inside of it, least not easy. The oil will coat the inside and you will be fine, if you go offroad alot close the ends up or clean the frame like monthly.
Old Jun 20, 2008 | 10:36 AM
Matt16's Avatar
Old Jul 2, 2008 | 10:19 AM
rodneyhanniford's Avatar
"92 4Runner blowing fuse
I need Help! I have a '92 4Runner that keeps blowing the 20 Amp wiper fuse at the driver side kick panel. Any suggestions on what may be wrong?
Old Jul 2, 2008 | 10:26 AM
dirtoyboy's Avatar
wow! Thats an awesome threadjack!
Old Jul 2, 2008 | 10:41 AM
Booosted Supra's Avatar
lol x2 haha
Old Jul 2, 2008 | 10:45 AM
4runnerguy's Avatar
nice put a bigger fuse
Old Jul 2, 2008 | 10:49 AM
1lowtoy's Avatar
X3 on the thread jack ahahaha, anyway, I think the best way to go is to pressure wash it, put a quart of oil in each of the frame rails and after it coats the inside of the frame, box the ends in so no dirt can get into them. Maybe you can make sort of a home made latch that allows you access to the frame inside to clean but when your off roading you can have it locked???
Old Jul 2, 2008 | 10:50 AM
dirtoyboy's Avatar
OK, back on topic...
I usually use a shop vac and a screwdriver to clean my frame out...
Old Jul 2, 2008 | 10:51 AM
WFO's Avatar
WFO
Tire foam. Just spray it on and walk away.
Old Jul 2, 2008 | 10:52 AM
dirtoyboy's Avatar
...if its boxed the smallest amount of moisture will stay inside creating rust....BUT it will stay cleaner inside...
If the frame is open it can drain and dry out completely BUT it gets a lot dirtier inside...
Which is better?
Old Jul 2, 2008 | 10:55 AM
4runnerguy's Avatar
your luky cause your frame is open
