clutch squeak?
Old Jun 24, 2008 | 02:09 PM
1992toyota4x4's Avatar
clutch squeak?
hey guys, lately ive been noticing a squeak in my clutch, it all works fine, and doesnt change anything, just squeaks when i push in the clutch, what could it be?
Old Jun 24, 2008 | 02:14 PM
Jay351's Avatar
Mine does it, look under the dash at the clutch pedal assembly. There will be a torsion spring tucked up in there. I tracked my squeeking down to that guy, I lubed it but it only lasted a day. I just turn the music up higher
Old Jun 24, 2008 | 02:15 PM
yotaphil's Avatar
my 86 does that too.. prolly just needs some WD40 or something idk
Old Jun 24, 2008 | 02:18 PM
Jay351's Avatar
I tried lithium grease in a can and it failed. Im not sure if wd40 would help.. but I suppose theres nothing to lose but 10 cents worth of lube.
Old Jun 24, 2008 | 02:23 PM
yotaphil's Avatar
yeai havent done anything but wd40 is the first thing that popped in my head
Old Jun 24, 2008 | 02:40 PM
874runnersr5's Avatar
hmm same problem.
il try some gig-a-loo see if it helps at all.
Old Jun 24, 2008 | 02:55 PM
86tuning's Avatar
Those pedal brackets tend to crack. Look very closely at the firewall area of the bracket.
And to properly lube that spring you need to use the special grease for polyurethane bushings.
Old Jun 24, 2008 | 03:06 PM
Jay351's Avatar
Thanks for the lube tip 86tuning.
Old Jun 24, 2008 | 03:38 PM
Luvmeye22re's Avatar
Are there return springs on the clutch/brake pedals?
Old Jun 24, 2008 | 03:41 PM
Jay351's Avatar
On the clutch pedal yes.
Old Jun 24, 2008 | 04:08 PM
cool thanks guys
Old Jun 24, 2008 | 07:40 PM
nmtoy's Avatar
There is a small plastic bushing that fits over the pin that connects the master cylinder pushrod to the clutch pedal.
The bushing will break eventually, if you replace it the squeak will go away.
Robb
Old Jun 24, 2008 | 07:53 PM
82greenbeast's Avatar
I used some thick park tool USA mtn bike crank grease, she worked mint!
kawazx636
Oct 6, 2021 03:03 PM
primordialbeast117
Dec 19, 2015 12:23 PM
smilen724
13
Nov 8, 2015 04:11 PM
hiluxinargentina
Sep 30, 2015 11:12 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
