Oil filter confusion
Old Jun 20, 2008 | 06:46 AM
plumo57's Avatar
Just went outside to change the oil on my '86 22RE... when i pulled the old filter, it was wet inside, but it didnt' seem like there was much oil in it. I know its slightly downward angled, so it could have drained back. Is this the case, or do i have oil problems? the oil pressure is good while its running.
Old Jun 20, 2008 | 06:54 AM
Hilux808's Avatar
If you let it sit long enough before you change oil some of the oil will drain back like you had thought, and your oil pressure is good. You'll be fine.
Old Jun 20, 2008 | 06:56 AM
plumo57's Avatar
it sat overnight, like 14 hours... Makes me nervous though. when i pulled it off, it didnt even drip any oil. There was oil inside the filter, but it didn't seem like much. I say the pressure is good... let me rephrase that... the gauge says it has oil pressure. How far i trust the gauge is another question altogether
Old Jun 20, 2008 | 07:04 AM
crews462's Avatar
Seems if the oil pressure is correct and the truck is running fine, you shouldn't worry about a thing. The filter probably just drained.
Old Jun 20, 2008 | 07:05 AM
waskillywabbit's Avatar
If when you check the oil at the dipstick it registers fine then you are being paranoid.
Old Jun 20, 2008 | 07:11 AM
corax's Avatar
the anti-drain back valve on some oil filters are cheap and don't do their job right. I usually use Purolator, but pay more for it. Fram filters only cost a few bucks for a reason . . .
Old Jun 20, 2008 | 07:25 AM
plumo57's Avatar
wish i could say i'd spent the money for a fram even... oh well. Probably am paranoid, but can't help myself sometimes. i appreciate the advice folks. if it blows up, i'll tell ya all about it. if not, i might just see you on the trail
Old Jun 20, 2008 | 09:00 AM
thook's Avatar
It's normal for the filter to be empty'ish/just wet after it's been sitting a while. Every filter I've ever used on my 22re does that. Well, I've only ever used WIX, but out of seven years they've all done that. And, they the have anti-drain valve.
Old Jun 20, 2008 | 09:10 AM
MMA_Alex's Avatar
most automotive filters have antidrainback valves...the fram ones just dont seal very well. either way after awhile any filter will drain back into the pan...unless its a filter with the opening upward on the engine
Old Jun 20, 2008 | 10:00 AM
abecedarian's Avatar
even with the anti-drainback valve, some of the oil will leak backwards through the oil pump. the valve is meant to keep the outlet passages to the block and head filled with oil so that the engine doesn't have to wait as long for oil.
the only cars I've seen with horizontal filters and a drainback valve that worked were my chrysler laser and vw sciroccos. always lost 1/2 cup oil every filter change.
Old Jun 20, 2008 | 10:10 AM
Belize Off Road Team's Avatar
Alot of time you are supposed to run you motor to temp before changing oil for that reason, it makes it easier to change. At least that is what i have been told by a very very experianced mechanic
Old Jun 20, 2008 | 10:24 AM
zlathim's Avatar
I think that has been widely accepted practice, but I got tired of burning my fingers/arms a long time ago.
Old Jun 20, 2008 | 12:20 PM
thook's Avatar
Egh....spoiled sport!.....
One of the main reason to get the motor hot before you drain is so that you get more of the used to drain out. It doesn't drain off as well when cold.
Old Jun 20, 2008 | 12:46 PM
huntnfreak's Avatar
i always stick with toyota oil filters
Old Jun 22, 2008 | 05:50 PM
TORTIS's Avatar
i use wix. they sent me a hat and stickers when i emailed them with a question.
Old Jun 22, 2008 | 07:08 PM
Pistonman's Avatar
Change it hot to keep contaminates suspended in the oil.
My motto is "Change it hot, change it alot"
Old Jun 22, 2008 | 08:08 PM
Luvmeye22re's Avatar
I wish TRD would send me some stickers and a hat lol
Eggslinger
Jun 8, 2019 03:32 PM
jasonty
41
Dec 23, 2018 01:00 PM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
calderp
Jul 27, 2015 09:58 AM
ryerye13
Jul 14, 2015 08:27 AM
