31's Rub on BJ Spacers?
Old Jun 21, 2008 | 12:19 PM
Trustyrusty's Avatar
Hey guys, Finally decided I'm getting 31x10.5x15 Treadwright M/T's and I need rims to put them on, I want Cragars D-Window Black steelies but I need to know what backspacing to get to make sure balljoint spacers WONT make the tires rub on the upper A-Arm, I would also like a little wider stance than I have, I will eventually be getting balljoint spacers up front and don't want them to rub when I install them, if anyone knows that would be great, I have no clue about rim backspacing or anything like that, thanks.
Old Jun 21, 2008 | 12:20 PM
Also what is my bolt circle spacing? I forgot..
Old Jun 21, 2008 | 12:24 PM
Alex 400's Avatar
6 on 5.5"
Old Jun 21, 2008 | 12:49 PM
Junkers88's Avatar
Why don't you use the stock rims? I used my alloys with some treadwright 31/10.50/15 OTR's and no lift and nothing rubs.
Old Jun 21, 2008 | 12:53 PM
Ever seen a stock rim off a base package '86. One word. FUGLY.
Old Jun 21, 2008 | 01:02 PM
Junkers88's Avatar
Ouch. I actually like my wheels although I'm not sure what the difference is between the SR5 package (mine) and a base package.
Old Jun 21, 2008 | 01:07 PM
http://img.photobucket.com/albums/v1...t/IM000421.jpg they look like Shokk88's? Or whatever his name is did.. Whats stock backspacing I hope someone will chime in..
Old Jun 21, 2008 | 02:55 PM
norcalsvx's Avatar
get some 15x8 4"backspace i run them with BJ spacers and 33's so youll be fine
Old Jun 21, 2008 | 03:36 PM
85toy's Avatar
he said he wants a wider stance so wouldnt 2" back spaceing be what he wants? or am i way off?
Old Jun 21, 2008 | 03:43 PM
thook's Avatar
Nope...that's right. The lesser the number, the wider the stance......the rim sticks out further from the hub.
Yeah....I have the stock steelies for my '86....6" wide. I don't know what the backspacing is, though. I can tell you any base or SR5 7" Toyota rim will solve the rubbing issue. But, again, I don't the backspacing.
Old Jun 21, 2008 | 06:46 PM
I think I want 3" backspacing If I can find it, 2" sounds 'tarded..
Old Jun 22, 2008 | 05:12 AM
Yopar's Avatar
My stock SR5 aluminum rims (like Junkers88 above) have 4.75" backspace. Now I am running the Tacoma 16" rim, which is more like 5".
Norcalsvx said use 4", which I think would be a good compromise of fitting, and a little wider stance than stock. Maybe go 3.5" but not any less, they'd stick out too far.
Old Jun 22, 2008 | 03:25 PM
Jay351's Avatar
I would go with a 15x8 with 3.75-4" of backspacing.
Im running 3.5" of backspacing and my tires stick out around 3".
4x4YOTA
Aug 23, 2016 09:08 AM
89YodaRunner
Sep 30, 2015 02:18 PM
JookUpVandetti
Sep 30, 2015 08:58 AM
myotherrideisayoshi
Sep 29, 2015 05:41 AM
crash813
Sep 27, 2015 07:15 AM
