engine wont start!!!!
Old Jun 18, 2008 | 11:41 AM
mungo06's Avatar
i just replaced the head and the timing chain on a '92 22re and put it back together and now it wont start, it has gas the timing is set and it wants to start but it wont, any advice would be great...
Old Jun 18, 2008 | 11:42 AM
DeathCougar's Avatar
back to basics kids.
Spark?
Fuel?
Timing?
Air?
sounds like you put the dizzy in 180 off
Old Jun 18, 2008 | 11:45 AM
mungo06's Avatar
the timing is fine and it has gas, i have no help at the moment to see if it has spark
Old Jun 18, 2008 | 12:05 PM
grab on the spark plug wire and crank it. I bet you find out quick
Old Jun 18, 2008 | 12:07 PM
Hilux808's Avatar
Did you check your distributor/ignition timing?
Old Jun 18, 2008 | 12:19 PM
mungo06's Avatar
how many times do i have to say the timing is fine and set up where it supposed to be, and for grabbing the wire im not stupid enough to grab hold of one
Old Jun 19, 2008 | 01:54 PM
mungo06's Avatar
truck runs but now it has a miss on cylinder two, no idea whats wrong
Old Jun 19, 2008 | 02:02 PM
ozziesironmanoffroad's Avatar
bro, calm down, being a jerk to people who are tryin to help you is going to get you nowhere. he said check the timing because a LOT of people set it 180 degrees off. extremely easy to. so dont get your panties up in a twist. and he was KIDDING about grabbing a wire and cranking. so come on dude, cool it.
in cyl 2, is there spark? what kind of compression you getting? spark plug wire okay? spark plug okay? is it throwing a code?
Old Jun 19, 2008 | 02:30 PM
Kaydon's Avatar
I think if I continue to hear people say calm down to someone else on the internet I'm gonna go around curb stomping people.
Check the plug, check the wires and make sure you have them right and the connections are good. Check the compression.
It may not hurt to play with the timing a little bit.
Check the valves.
Did you replace the head due to a warped beyond machining or cracked head? Where'd you get the replacement from? Could explain some things.
Sounds like you're not getting spark to that cylinder, but it could be fuel. Check the injectors?
Old Jun 19, 2008 | 02:35 PM
Check the valves.
Did you replace the head due a warped beyond machining or cracked head? Where'd you get the replacement from? Could explain some things.
bahahahaha
Kaydon to the comedic rescue!
Old Jun 19, 2008 | 02:37 PM
Evil.Dingo's Avatar
South Carolina, Sumter.
oops here goes a thread hijack!
Kaydon.... you at Shaw?
Old Jun 19, 2008 | 02:44 PM
He's at redneck, thats what he is at :flipoff:
Old Jun 19, 2008 | 02:46 PM
Look smart guy, if you are smart enough NOT to grab the wire, you MUST be smart enough to pull the plug, and put it into the wire, then ground the threads of the plug and watch for spark.
Right?
Old Jun 19, 2008 | 02:51 PM
abecedarian's Avatar
Right?
okay... what's the flavor tonight? ale, pilsner, lager?
Old Jun 19, 2008 | 02:52 PM
Ya know, i think im actually going for Stout tonight. Something dark and delicious. Not too bitter though, it doesn't settle right.
Old Jun 19, 2008 | 02:55 PM
Kaydon's Avatar
Is this gonna be another "oil cap removed, runs weird" thread?
Old Jun 19, 2008 | 02:56 PM
Ever had an irish carbomb? guiness stout in a glass, double-shot glass with 1 shot Jameson and one shot Bailey's. Carefully drop the double into the guiness and drink quickly. 3-4 and you'll be arssed out.
Old Jun 19, 2008 | 02:57 PM
Don't tell DC... but I'm trying to distract him so another internet fight doesn't break out and you don't get upset about people telling others on the internet to calm down.
Old Jun 19, 2008 | 02:58 PM
When ya start gettin smart with us....
Old Jun 19, 2008 | 02:59 PM
Kaydon's Avatar
LOL!
Btw, your PM box sucks DC.
